RAX Patch - ROM patches
Old Mar 15, 2012 | 02:23 AM
  #76
Bob_tm's Avatar
tnx! Will test it on week or two!
Old Mar 23, 2012 | 04:59 AM
  #77
Clipse3GT's Avatar
Rich,
Is there a version of the 2008 MR SST version of RAX with Baro compensation?
~Kris
Old Mar 23, 2012 | 05:42 AM
  #78
richardjh's Avatar
Hi Kris.
Not yet - it's high time I whipped 'em up! I'll get on it now...
Rich
Old Mar 23, 2012 | 07:38 AM
  #79
Clipse3GT's Avatar
Originally Posted by richardjh
Hi Kris.
Rich
Sweet
Old Mar 23, 2012 | 10:01 AM
  #80
richardjh's Avatar
Hi Kris.
Hot off the press, please try this new revision of RAX Patch for USDM 2008 SST. That's got Atmospheric Boost Baro Compensation in it.
Remember to set "Atmospheric Boost" constant to 0. That will wake the patch up and get it feeding in a baro-sensor measured value.
Tomorrow, I'll update the first post with new links, etc. It's just too late to do it right now! I'm off to get some well-earned zzzzzzzzzzz....
Rich
Old Mar 23, 2012 | 05:31 PM
  #81
richardjh's Avatar
I have added support for Atmospheric Boost Baro Compensation patch to Evo X SST ROMs. The first post has updated download links.
Also, if anyone actually uses it, the SST Upshift Boost EC Management patch has a minor revision. I found it could be confused by jittery RPM in tall gears - in theory, this could result in upward EC being zeroed out when not actually upshifting. I've tweaked it so it's a bit less sensitive.
This whole area will get easier if/when I find a magic bitflag that means "SST Upshift in progress".
Anyway, it's dead easy to update the patch code. You can cycle the relevant "subroutine" selection from "Old Code v1r7" -> "Code PRESENT".
Seeing as there's revised/new code in the Evo X SST patch downloads, I've put all of the "Testing" status indicators back to Untested.
Enjoy!
Rich
Old Mar 25, 2012 | 01:33 AM
  #82
Clipse3GT's Avatar
Thanks for the updates.
I think you are missing the 2008 JDM SST/5MT maps as well.
Old Mar 25, 2012 | 02:52 AM
  #83
richardjh's Avatar
Yeah... this is a pester-power service line. Nagging ----> Patch!
Rich
Old Mar 27, 2012 | 12:29 PM
  #84
bobby.is.rad's Avatar
Thanks for this!
Old Mar 27, 2012 | 03:06 PM
  #85
momostallion's Avatar
Be back home in the loving arms of evo tonight. Will be able to finally test rax2 tonight/tomorrow morning.
Old Mar 27, 2012 | 03:41 PM
  #86
richardjh's Avatar
Great, thanks. Please be sure to follow the (conservative and boring) testing recommendations in the pdf.
Rich
Old Mar 28, 2012 | 07:53 AM
  #87
fostytou's Avatar
EvoM Community Team
Hi Richard,
I'm not sure if you are looking for suggestions, but the SST upshift management got me thinking that it might be nice to have a timing upshift management. On the CT9A and when I was looking at my old X maps we used to have to reduce timing in the shift area to prevent knock on shift (since it would rapidly enter the ~140 load / 6500RPM area of the map and have sky high timing).
Also, if you are doing NLTS or faux NLTS the upshift boost control might be helpful for 5MT too.
I'm not sure if it would help your disassembly but for the CT9A there was a bit-flag that you could log for clutch in. It would read multiple parameters through one address, but clutch and brakes were in there.
Old Mar 28, 2012 | 08:29 AM
  #88
richardjh's Avatar
Yeah, I've found two "brake" bitflag addresses. I bet that one of them is the clutch-bit style variable on 5MT Evos.
It would be easier checking that than the irritating way I "had" to do things. I still want to find an SST upshift bitflag. Once I find that it will allow me to do an integrated 5MT and SST version of this upshift patch.
And regarding 5MT NLTS upshift timing retard... that wouldn't be too difficult. The stock "SST upshift timing retard" code is a million times more complicated than anything we'd need for 5MT... so as long as we kept it simple, it would probably come out alright.
Rich
Old Mar 28, 2012 | 09:31 AM
  #89
RazorLab's Avatar
Originally Posted by fostytou
Hi Richard,
Have you tried using the Lower Bound Timing Table on the 5MT?
I actually haven't ever tried it on the 5MT, I wonder if it works on shifts like it does on the SST, maybe it uses the clutch switch?
Old Mar 28, 2012 | 11:34 AM
  #90
Rich
applied Rax Patch for 58010005/58010105
applied patch to rom successfully.
flashed successfully.
logged successfully.
iat adjustment of .5 shown on partial throttle run into low boost.
baro shows 14.5
looks like a success to me!
