Requested Torque/Throttle Ramp Rate Tables
Old Jun 1, 2013 | 02:22 AM
  #46
James15d's Avatar
how about for the 2008 JDM GSR #52360018... thanks
Old Jun 2, 2013 | 06:47 AM
  #47
rpacheco's Avatar
Originally Posted by 99EclipseGSX
Anyone found these on the 59580004 '13 Evo X?
PM me your rom and I can find it for you.
Old Dec 30, 2013 | 05:58 AM
  #48
quicksilver7's Avatar
Can anyone help me find the table for my 2010 JDM 56180001 rom? My throttle response is sooo laggy
File Type: hex
Old Dec 31, 2013 | 11:38 PM
  #49
RS200Z's Avatar
Here you go.
Code:
<table name="Requested Torque Ramp Rate - SST Normal Mode" category="Torque" address="5F5C7" type="3D" swapxy="true" scaling="Percent">
	<table name="VehicleSpeed" address="62544" type="X Axis" elements="6" scaling="VehicleSpeed"/>
	<table name="RevPerMPH" address="628D2" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
</table>
<table name="Requested Torque Ramp Rate - SST SPORT Mode" category="Torque" address="5F58F" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - SST S-SPORT Mode" category="Torque" address="5F557" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5F51F" type="3D" swapxy="true" scaling="Percent">
</table>
Old Jan 1, 2014 | 06:08 AM
  #50
Originally Posted by RS200Z
Here you go.
Code:
</table>
</table>
</table>
</table>
Thank you!!
Old Feb 14, 2014 | 12:17 PM
  #51
Treyzian's Avatar
Bringing this back up. So what is everybody changing the values in this table to? 100 across the board?
Old Feb 14, 2014 | 02:38 PM
  #52
chetrickerman's Avatar
Veteran: Army
for the 5mt, yes
Old Feb 16, 2014 | 06:08 AM
  #53
hmm somehow i feel no difference before and after changing these values
Old Feb 17, 2014 | 02:41 PM
  #54
nonschlont's Avatar
any 1 found the addresses for 56890013, yet? Maybe even the throttle requested torque subtractor map?.?.?.
Old Feb 17, 2014 | 04:35 PM
  #55
Veteran: Army
I did on evox
Old Jul 30, 2016 | 02:41 AM
  #56
droo00's Avatar
Hey guys
I recently made some tune in my evo x Mr. Gear changes on auto normal seems very weird. Between gears there's a lag before the next gear engages, especially during slow stoves like 2000. 3000 rpm changes.
I have a JDM 08
? Anyone can help
Is it something to do with the ramp map. Can someone help please?
Old Jul 30, 2016 | 05:45 AM
  #57
Beeble's Avatar
gentle changes.
you can go too far with the sst maps and make it worse
go back to stock values , and increase just a little
my guess is you raised things too high in the ramp up or the throttle requested torque
Old Jul 31, 2016 | 10:18 PM
  #58
droo00's Avatar
Originally Posted by Beeble
gentle changes.
Thanks. Can someone share a good clean stock map?
I was just thinkin, dies the SST maps have any relation to how the engine is tuned globally like timing and fuel naps?
Old Aug 18, 2017 | 12:56 PM
  #59
Banstett's Avatar
Help!! Don't see ramp rate table!
Only requested torque table shows, not ramp rate table.
I can't seem to figure out why the ramp rate table doesn't show in my ecuflash after I input the definitions for 52680022. any help would be great!
Originally Posted by tephra
A thread on EXF has spurred me to post this information.
These maps control how fast the Requested Torque and therefore TPS will ramp up to the target depending on what sort of vehicle you drive.
ie there is a map for Manuals (5MT) and 3 maps for SST (which related to the 3 modes, Normal , Sport, SSPORT)
These will be making their way into COBB AP asap as well
But in the mean time please test these carefully
2008 USDM X - 5268/5269:
Code:
<scaling name="Percent" units="%" toexpr="x*100/255" frexpr="x*255/100" format="%.1f" min="0" max="100" inc="2" storagetype="uint8" endian="big"/>
<table name="Requested Torque Ramp Rate - SST Normal Mode" category="Torque" address="5f4dd" type="3D" swapxy="true" scaling="Percent">
<table name="VehicleSpeed" address="622ec" type="X Axis" elements="6" scaling="VehicleSpeed"/>
<table name="RevPerMPH" address="62678" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
</table>
<table name="Requested Torque Ramp Rate - SST SPORT Mode" category="Torque" address="5f4a5" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - SST S-SPORT Mode" category="Torque" address="5f46d" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5f435" type="3D" swapxy="true" scaling="Percent">
</table>
2008/2009/2011 AUDM/EDM X - 53040010/53050009:
Code:
<table name="Requested Torque Ramp Rate - SST Normal Mode" category="Torque" address="5f519" type="3D" swapxy="true" scaling="Percent">
<table name="VehicleSpeed" address="62328" type="X Axis" elements="6" scaling="VehicleSpeed"/>
<table name="RevPerMPH" address="626b6" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
</table>
<table name="Requested Torque Ramp Rate - SST SPORT Mode" category="Torque" address="5f4e1" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - SST S-SPORT Mode" category="Torque" address="5f4a9" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5f471" type="3D" swapxy="true" scaling="Percent">
</table>
2010 USDM RA - 55590007:
Code:
<table name="Requested Torque Ramp Rate - SST Normal Mode" category="Torque" address="5f5c7" type="3D" swapxy="true" scaling="Percent">
<table name="RevPerMPH" address="628d2" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
</table>
<table name="Requested Torque Ramp Rate - SST SPORT Mode" category="Torque" address="5f58f" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - SST S-SPORT" category="Torque" address="5f557" type="3D" swapxy="true" scaling="Percent">
</table>
2011 AUDM/EDM X - 56910007/56920006:
Code:
<table name="Requested Torque Ramp Rate - SST Normal Mode" category="Torque" address="5f853" type="3D" swapxy="true" scaling="Percent">
<table name="VehicleSpeed" address="62ce8" type="X Axis" elements="6" scaling="VehicleSpeed"/>
<table name="RevPerMPH" address="63088" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
</table>
<table name="Requested Torque Ramp Rate - SST SPORT Mode" category="Torque" address="5f81b" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - SST S-SPORT Mode" category="Torque" address="5f7e3" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5f7ab" type="3D" swapxy="true" scaling="Percent">
</table>
2010 USDM X - 55570006/55580006:
Code:
</table>
</table>
<table name="Requested Torque Ramp Rate - SST S-SPORT Mode" category="Torque" address="5f557" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5f51f" type="3D" swapxy="true" scaling="Percent">
</table>
Cheers
D.
Old Aug 1, 2018 | 01:02 AM
  #60
crimson red's Avatar
Did you add the scaling definition named "Percent"?
Checking 'Show Invalid Tables', 'Show Invalid Leaf Tables' ecuflash option may help you. ( this shows the tables which are not defined properly.)
tephra
70
Jul 11, 2024 12:59 AM
Mattjin
Apr 8, 2024 05:34 PM
tephra
Jan 28, 2018 04:37 PM
tephra
151
Jun 18, 2017 03:22 PM
tephra
May 16, 2016 09:24 PM
