Requested Torque/Throttle Ramp Rate Tables
Old Oct 14, 2011 | 08:34 PM
tephra's Avatar
A thread on EXF has spurred me to post this information.
These maps control how fast the Requested Torque and therefore TPS will ramp up to the target depending on what sort of vehicle you drive.
ie there is a map for Manuals (5MT) and 3 maps for SST (which related to the 3 modes, Normal, Sport, SSPORT)
These will be making their way into COBB AP asap as well
But in the mean time please test these carefully
2008 USDM X - 5268/5269:
Code:
<scaling name="Percent" units="%" toexpr="x*100/255" frexpr="x*255/100" format="%.1f" min="0" max="100" inc="2" storagetype="uint8" endian="big"/>
<table name="Requested Torque Ramp Rate - SST Normal Mode" category="Torque" address="5f4dd" type="3D" swapxy="true" scaling="Percent">
	<table name="VehicleSpeed" address="622ec" type="X Axis" elements="6" scaling="VehicleSpeed"/>
	<table name="RevPerMPH" address="62678" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
</table>
<table name="Requested Torque Ramp Rate - SST SPORT Mode" category="Torque" address="5f4a5" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - SST S-SPORT Mode" category="Torque" address="5f46d" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5f435" type="3D" swapxy="true" scaling="Percent">
</table>
2008/2009/2011 AUDM/EDM X - 53040010/53050009:
Code:
<table name="Requested Torque Ramp Rate - SST Normal Mode" category="Torque" address="5f519" type="3D" swapxy="true" scaling="Percent">
	<table name="VehicleSpeed" address="62328" type="X Axis" elements="6" scaling="VehicleSpeed"/>
	<table name="RevPerMPH" address="626b6" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
</table>
<table name="Requested Torque Ramp Rate - SST SPORT Mode" category="Torque" address="5f4e1" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - SST S-SPORT Mode" category="Torque" address="5f4a9" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5f471" type="3D" swapxy="true" scaling="Percent">
</table>
2010 USDM RA - 55590007:
Code:
<table name="Requested Torque Ramp Rate - SST Normal Mode" category="Torque" address="5f5c7" type="3D" swapxy="true" scaling="Percent">
	<table name="VehicleSpeed" address="62544" type="X Axis" elements="6" scaling="VehicleSpeed"/>
	<table name="RevPerMPH" address="628d2" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
</table>
<table name="Requested Torque Ramp Rate - SST SPORT Mode" category="Torque" address="5f58f" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - SST S-SPORT" category="Torque" address="5f557" type="3D" swapxy="true" scaling="Percent">
</table>
2011 AUDM/EDM X - 56910007/56920006:
Code:
<table name="Requested Torque Ramp Rate - SST Normal Mode" category="Torque" address="5f853" type="3D" swapxy="true" scaling="Percent">
	<table name="VehicleSpeed" address="62ce8" type="X Axis" elements="6" scaling="VehicleSpeed"/>
	<table name="RevPerMPH" address="63088" type="Y Axis" elements="8" scaling="RPMPerMPH"/>
</table>
<table name="Requested Torque Ramp Rate - SST SPORT Mode" category="Torque" address="5f81b" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - SST S-SPORT Mode" category="Torque" address="5f7e3" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5f7ab" type="3D" swapxy="true" scaling="Percent">
</table>
2010 USDM X - 55570006/55580006:
Code:
</table>
</table>
<table name="Requested Torque Ramp Rate - SST S-SPORT Mode" category="Torque" address="5f557" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Requested Torque Ramp Rate - 5MT" category="Torque" address="5f51f" type="3D" swapxy="true" scaling="Percent">
</table>
Cheers
D.
Old Oct 14, 2011 | 08:52 PM
chetrickerman's Avatar
Veteran: Army
Awesome. Thanks.
What about the Throttle requested Torque Subtractor Percent map?
Old Oct 14, 2011 | 09:08 PM
Hakke's Avatar
thank you tephra! we appreciate all that you do!
Old Oct 14, 2011 | 09:34 PM
tephra's Avatar
Originally Posted by chetrickerman
Awesome. Thanks.
that can be another thread...
Old Oct 14, 2011 | 11:18 PM
korzunm's Avatar
Thanks, nice work
Old Oct 14, 2011 | 11:45 PM
richardjh's Avatar
Thanks - I'll do the Ralliart Table Dance. Which doesn't involve beer and strippers. Unfortunately.
Rich
Old Oct 14, 2011 | 11:50 PM
tephra's Avatar
oh I remembered I had Bryan's ROM already done - so I posted 55590007
Old Oct 15, 2011 | 12:19 AM
Evod350z's Avatar
Is this different than the 1st gear limiter? Can you explain this more so i can have my tuner run this on my SE.
Old Oct 15, 2011 | 12:57 AM
Bernhard's Avatar
Here is the definition for 5692(0006) that I made some time ago with Tephra's help:
Code:
<table name="Throttle Ramp Rate - SST Normal Mode" category="Throttle" address="5f853" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Throttle Ramp Rate - SST SPORT Mode" category="Throttle" address="5f81b" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Throttle Ramp Rate - SST S-SPORT Mode" category="Throttle" address="5f7e3" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Throttle Ramp Rate - 5MT" category="Throttle" address="5f7ab" type="3D" swapxy="true" scaling="Percent">
</table>
Before today those tables were named "Mode Engagement" and were in the SST category. I just manipulated my definitions using a text editor. I hope they will work out of the box.
Old Oct 15, 2011 | 02:50 AM
tephra's Avatar
The limiters are just that - an upper limit.
These maps control how fast the throttle will reach the target.
Sometimes its desirable for the throttle to open a bit slower than the user is requesting. Ie Low Gear/Low Speed...
Old Oct 15, 2011 | 03:14 AM
tephra's Avatar
I just went back an double checked the code, and these maps actually control how fast the ECU will ramp the requested torque output.
This of course goes into the Throttle decision process, so directly these will control the Throttle.
But I thought I would point it out just incase
I might rename them to "Requested Torque/Throttle Ramp Rate..."
Old Oct 15, 2011 | 07:01 AM
ikoval's Avatar
In 53040007 case I'm getting something that does not look like right data. Can you please take a look on that?
Requested Torque/Throttle Ramp Rate Tables-throttle.jpg
I have used xml quoted below.
Originally Posted by tephra
5304/5305:
Code:
<table name="Throttle Ramp Rate - SST Normal Mode" category="Throttle" address="5f519" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Throttle Ramp Rate - SST SPORT Mode" category="Throttle" address="5f4e1" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Throttle Ramp Rate - SST S-SPORT Mode" category="Throttle" address="5f4a9" type="3D" swapxy="true" scaling="Percent">
</table>
<table name="Throttle Ramp Rate - 5MT" category="Throttle" address="5f471" type="3D" swapxy="true" scaling="Percent">
</table>
Old Oct 15, 2011 | 08:17 AM
tephra's Avatar
upgrade to 53040010
Old Oct 15, 2011 | 08:22 AM
Veteran: Army
check my posts in the thread on EXF
Old Oct 15, 2011 | 10:03 AM
jyamona's Avatar
can you post the 5MT one for 55570006 please? =)
