fuel cut? log inside please help?
Old Oct 19, 2011 | 07:18 AM
PrimerSdime's Avatar
It should be set approximately 10% higher than your normal load at the given rpm. So, if you normally hit 300% load at 4000 rpm, you should have it set at 310% at 4000 rpm.
I don't have any experience with Tephra, so someone else will have to chime in with what you should do.
Old Oct 22, 2011 | 03:06 AM
Expand the miscellaneous tephra mods menu and change your 2byte to 1byte load factor from 1.2 to something higher. Raising the load factor to 1.3 will give you a max load of 331.5.
Old Oct 22, 2011 | 10:30 PM
Also, don't forget to change the function formula in EvoScan to 1.3.
overdrive1
Dec 21, 2014 06:03 AM
hyeteck
Jan 8, 2010 12:00 AM
rodent
AEM EMS
Oct 30, 2009 12:31 AM
steelcityevo8
20
Jun 20, 2005 03:47 AM
stratis
Jul 22, 2004 05:34 AM
