WGDC ? - Boost tuning V7
Old Dec 17, 2011 | 06:24 AM
catman78's Avatar
hi all,
My thick head can't get around this, so bear with me.
I'm trying to tune my boost curve.
The following are zeroed out during process:
BEC
Max upward vs TPS
Desired Load
Boost adder
WG under load 100% ... = 150.
upper and lower correction intervals are set to 1.
Should I assume my WGDC will follow my Main Map WGD?
Log shows wgdc @ 100 until 150 load is passed, say @ 3000 rpm.
If my Main Map WDG is set @ 50 from 3000-4000 rpm.
Why would log show the following from 3 to 4 k
100 @ 150 load
3000 22
.. 22.5
.. 25
4000
@ each log record 1.5 is being added.
I would expect my WGDC to follow my Main Map WGD as such
1000
50
50
50
thanks
Old Dec 17, 2011 | 08:29 AM
charlie.tunah's Avatar
Some pictures of your maps would help. But with psi-based control, you set the boost adder to the atmospheric pressure of your location. So in load-based control, that number may need to be 100 (for 14.7psi, or lower for your altitude). I havent tried to tune load-based boost yet, so that may be way off base. But it would kindof make sense that you hit 150, then boost control takes over and things get screwy. Also, I dont think there is anything wrong with setting the "WGDC = 100% under this load" to 0. Then put it back to where you think it needs to be after dialing in your wgdc maps. Im willing to bet that if you set it to 0, you wont ever hit 100 that you are currently logging, because the wgdc maps arent set up correctly.
Old Dec 17, 2011 | 08:56 AM
catman78's Avatar
hey tunah, what's up. Hope there's no snow up there yet.
I think I'll give that a shot as far as WGDC 100%.
Keep it @ 0 and see if logged WGDC follows my Main WG Map.
If that doesn't work I'll post up my maps.
Load Correction works as expected. Basically log load and throw the
desired "load" in table along with load adder.
I'll report back.
Old Dec 17, 2011 | 09:00 AM
Raptord's Avatar
Agree with Charlie that pics of your map would help. Also, is your MAF IAT vs WGDC table zero'ed out as well?
Old Dec 17, 2011 | 09:19 AM
catman78's Avatar
ok guys, here we go.
raptord,, Logged MAF temp was around 65 F.
i can zero that also, to possibly remove another variable
Keep in mind, I did change WGDC 100 to 0 as per tunah's suggestion. Haven't tested yet.
Old Dec 17, 2011 | 09:46 AM
Raptord's Avatar
Correction interval isn't a factor right now since you have correction zero'ed out. From what I see there, yes, the ECU should be simply following your BWGDC map.
Check TPS WGDC correction and max WGDC vs coolant temp to make sure those 2 tables aren't modifying your BWGDC. If TPS WGDC has 50 at WOT then it'll take whatever value is in your BWGDC table and halve it, for example.
Can you also post the log?
Old Dec 17, 2011 | 09:56 AM
please be careful with setting the adder to 100. Id try the wgdc under this load to 0 1st.
Old Dec 17, 2011 | 09:59 AM
"if you logged 240 load @ 3500RPM, then the "Boost Control Load Offset" would be 100 and the "Boost Desired Engine Load" to be 140 @ 3500RPM."
Boost "adder" used to be refered to as "offset".
from
https://www.evolutionm.net/forums/ec...-solenoid.html
Old Dec 17, 2011 | 10:03 AM
what do your boost desired load tables look like?
nevermind...none of that should even matter. youre just trying to get it to run map wgdc.. adder and desired load only work with correction.
Old Dec 17, 2011 | 10:09 AM
^^its gotta be something like this since its pretty much half the expected value.
Old Dec 17, 2011 | 11:00 AM
catman78's Avatar
I'm ice skating w my kids
I'll post a few logs in a bit
Old Dec 17, 2011 | 01:08 PM
catman78's Avatar
Gold Star Raptord.
SOB, that was it. Zeroed it out @ upper temps and no addition to WGDC.
WGDC follows whatever I throw in there.
left vs right
As usual thanks for all your help guys(Raptord / Charlie)
time for a cocktail.
Enjoy you holidays guys
Got myself a little Christmas present. Gonna go on the stock block for few months.
then slap it on to my almost complete 2.4. s/b a rip on the 2.4
https://www.evolutionm.net/forums/sa...turbo-kit.html
Old Dec 17, 2011 | 01:57 PM
Raptord's Avatar
Glad I could help!
S15me2
Dec 8, 2016 08:22 PM
tenney
May 12, 2016 03:29 AM
roni4g63
Nov 22, 2015 02:54 PM
mrfred
Nov 25, 2011 09:51 PM
Raceghost
Sep 14, 2009 05:46 AM
