Total NEWBIE question
Old Dec 24, 2011 | 02:44 PM
DANNY08GSR's Avatar
I purchased ECUFlash and the obd cable and am attempting to load the OBDii Inspection test patch. My ROM ID is 52680017 and its a 2008 EVO X GSR.
When I open the metadata xml file for 52680017, the only thing in the file is this....
<rom>
<romid>
<xmlid>52680017</xmlid>
<internalidaddress>5002A</internalidaddress>
<internalidhex>52680017</internalidhex>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Lancer</model>
<submodel>Evolution X</submodel>
<transmission>5MT</transmission>
<year>2008</year>
<flashmethod>mitsucan</flashmethod>
<checksummodule>mitsucan</checksummodule>
<memmodel>M32186F8</memmodel>
</romid>
<include>52680015</include>
</rom>
Others are MUCH longer, am I doing something wrong. Also, I cant find the code for the patch for force all inspection test to pass for that rom ID.
Please, any help would be awesome, I am new to all of the "tuning" struff....
Thanks guys
Old Dec 24, 2011 | 02:48 PM
sstevojr's Avatar
You need to upgrade your stock 0015 to the 0017
EDIT: Looks like it is, so you also need to download the definitions for 0015
Old Dec 24, 2011 | 04:02 PM
DANNY08GSR's Avatar
Thanks Steve-o
I guess i understand what you mean in theory....but how do i actually go about doing it?
Thanks again and merry xmas.
Old Dec 24, 2011 | 05:16 PM
sstevojr's Avatar
Same way you got the 0017 definitions. And be sure to put them in same meta-folder. Use these:
http://goldenevo.com/
Old Dec 25, 2011 | 04:01 AM
DANNY08GSR's Avatar
When I click on the link for 52680017 it just show what I already have for that file in the metedata folder...
<rom>
<romid>
<internalidaddress>5002a</internalidaddress>
<year>2008</year>
</romid>
</rom>
I dont understand the "base file" referencing 52680015. Do I need to copy the xml from that base file (52680015) into my rom id metadata file?
Old Dec 25, 2011 | 06:48 PM
sstevojr's Avatar
bingo
Old Dec 25, 2011 | 11:29 PM
richardjh's Avatar
You don't actually need to copy the contents of one file into the other.
Simply ensure that BOTH the 52680017.xml and 52680015.xml are present.
One references ("includes") the other.
Rich
Old Dec 26, 2011 | 09:02 AM
sstevojr's Avatar
Correct. I misunderstood the question, thought you were saying metadata folder, didn't see you put metadata "file".
Old Dec 26, 2011 | 10:36 AM
DANNY08GSR's Avatar
Ok, I am getting closer. I copied a patch into the 0015 file for the OBD inspection test and can now see that area of the ROM. What table do I need to change in order to set them to "pass"
Old Dec 26, 2011 | 03:43 PM
sstevojr's Avatar
It should say on the patch, XXXX->YYYY
Old Dec 27, 2011 | 06:53 AM
DANNY08GSR's Avatar
ok....im getting closer yet, thanks to your help. When I change the hex values, I show all "0"s for available / not avail
and all "1"s for pass / fail.
shouldn't the avail/non avail table show all 1's?
Can I change individual tests so that the tests that dont apply show as such.
If I set a test to "NOT AVAILBLE" like the "SECONDARY AIR SYSTEM" what should the pass / fail table show? 1 or 0
Thanks again, and again, and again....
Old Dec 27, 2011 | 10:43 AM
sstevojr's Avatar
I don't know any specifics on this patch, you might want to go to the thread that talks about it. I'm not familiar with the 'intended' results, sorry
Old Jan 3, 2012 | 07:56 AM
Golden's Avatar
When you do the OBD Inspection patch, simply change the values in the 3 "Non-Continuous" tables.
Do NOT touch the 2 tables that start with "Monitor".
After you change the 3 tables you are setup correctly.
The Monitor Available table will show all 0's, The Monitor Passed table will show all 1's.
Old Feb 12, 2012 | 07:09 PM
shawnburch's Avatar
Subscribing. I hooked my tactrix up for the first time last night, and got the same exact thing except mine said 55580005 but nothing else. I downloaded 0006 but my computer wont open it. Now my computer wont even read the ECU, just keeps saying failed. Gonna have my buddy wipe my computer and get rid off all the **** I have on here. Hopefully that fixes it.
Old Feb 27, 2012 | 05:41 PM
importunerdj's Avatar
Thread bump....what is this obd inspection patch?
Hiram6g74
Feb 22, 2018 03:00 PM
jakgal04
Sep 20, 2017 08:09 PM
PPM
Apr 2, 2015 09:35 AM
got boost??
Sep 12, 2014 12:34 PM
wreckleford
Lancer Engine Management / Tuning Forums
May 20, 2012 11:35 AM
