cant log fuel trims
Old Mar 20, 2012 | 03:38 PM
stinkbomb's Avatar
cant log fuel trims
anybody have any ideas hit me up. cant log any fuel trims. they just stay @ zero. never move. replaced front o2 sensor and rear o2 sensor is not deleted. checked all fuses. anybody have any ideas. cant scale in my injectors
Old Mar 20, 2012 | 03:49 PM
tscompusa's Avatar
are you tuning it yourself now? maf ? sd? if sd.. i dont even use fuel trims half the time.. the name of the game is to keep AFR's at or around 14.7 on cruising/driving conditions .. that = smooth sailing.. no lean spike jitter, none of that garbage. (open loop)
airflow hz can effect trim crossover - you adjust that via lt trim control tables.. prob need to add it to your xml though.
global scaling is in direct correlation with fuel map values / as is maf tables, so even if theres no o2 feedback on a car u will know whats right & whats wrong.
Old Mar 20, 2012 | 05:08 PM
stinkbomb's Avatar
no not tuning it myself. havent got 4 bar yet. just trying to get it a little better. also the maf translator was bad. put stock maf on and idled like butter. just dont know why i cant log trims. just seemed odd they never move.
how would u scale injectors if fuel trim no worky?
Old Mar 20, 2012 | 08:15 PM
tscompusa's Avatar
tell me what size injectors and what fuel you're using and ill post some scaling & latency for you.
Old Mar 21, 2012 | 05:27 AM
stinkbomb's Avatar
e85 and pte 1200s thanx
also map sensor should be here today
Old Mar 21, 2012 | 09:38 AM
tscompusa's Avatar
713 scale
latency
3.312
2.592
1.632
1.2
0.792
0.48
0.504
good stuff.
Old Mar 21, 2012 | 01:10 PM
stinkbomb's Avatar
sent u a email. got map sensor 2day
Raceghost
Dec 15, 2016 02:54 PM
ridenrunwv
Aug 20, 2015 07:19 AM
Toxin
Apr 18, 2013 03:20 PM
3gEclipseTurbo
Jan 28, 2010 01:41 PM
golruss
Jul 9, 2009 05:43 PM
