Ful cut but why??
Old Mar 28, 2012 | 06:03 PM
  #31
merlin.oz's Avatar
I dont see how, but maybe the stationary rev limit is engaging???
I would still try setting boost cut delay to max to see if it is a load or rev related issue.
Old Mar 28, 2012 | 06:14 PM
  #32
wizzo 8's Avatar
My stationary is set to 6281. My boost cut and time is maxed out. Along with fuel cut
Old Mar 28, 2012 | 06:23 PM
  #33
merlin.oz's Avatar
ok, weird.
possibly a bad def and something has been set that was unintended?
what address does your def say for revlimit and speed limit?
Old Mar 28, 2012 | 06:36 PM
  #34
wizzo 8's Avatar
ok, weird.
Address for rev limit is 158c and speed 158e
Old Mar 28, 2012 | 06:55 PM
  #35
merlin.oz's Avatar
Those are the correct address.
Old Mar 28, 2012 | 06:59 PM
  #36
wizzo 8's Avatar
Thanks for your input Merlin. Also thanks for the tuning manual. Im going to change the spark plugs. If that fixes it then thank god and 3K
Old Mar 28, 2012 | 07:07 PM
  #37
tscompusa's Avatar
Originally Posted by wizzo 8
If I remember correctly Mellon pushed 700whp on the stock maf with honycomb removed. Mine is removed also
i hit 570 load on the maf a few times at 44psi.
based on your last response after i gave you information, it sounds like its not a consistent problem but off and on.. its the spark plugs or the ignition system failing most likely. hopefully its not the fuel pump or injector related.
Old Mar 28, 2012 | 07:14 PM
  #38
tscompusa's Avatar
wizzo you dont have NLTS turned on do you? ive seen that go nuts before.. just thought id throw that out there also.
Old Mar 28, 2012 | 07:21 PM
  #39
wizzo 8's Avatar
It is active. I will deactivate it. Since I did change the spark plugs at the same time I replaced the cams I will change those out also. I think we are getting to the bottom of this.
Old Mar 28, 2012 | 07:38 PM
  #40
tscompusa's Avatar
if you try to lift shift with NLTS activated the car will freak out inbetween shifts.
dont ask me how i know.
Old Mar 28, 2012 | 08:13 PM
  #41
merlin.oz's Avatar
I dont think you mentioned what coil setup you have, but what you are describing is fuel-cutting, not plug/coil problems. I think tsc is on money re NLTS.
Mind you, if you are running those numbers on the stock coil setup, well I guess you will find the limits soon, hehe.
Old Mar 31, 2012 | 11:14 AM
  #42
wizzo 8's Avatar
Originally Posted by 3K
It's probably your spark plugs. I had the same thing happen to me, it kept cutting at 5500rpm. I thought it was the ecu. I made a fresh rom copied over the maps. Nothing still fuel cut. I thought my licp might have been leaking, changed it. Still fuel cut. Thought my pump was going out, changed it. Still fuel cut. I never suspected the plugs because I just changed them about a month before all this happened. Changed the plugs and the fuel cut went away.
Doesn't hurt to try the cheapest route. spark plugs.
Well this was the problem. for 3K. I couldnt believe it. I installed some iridium plugs and now it pulls to redline without any problems. I know what it feels like when the gap is too big and it breaks up up top but this was like I was hitting a wall. Im also not sure why this would cause my afrs to sky rocket when it happened. You would think it would go rich. Well either way its fixed. Thanks for all the help Raptord, Tcomp, Merlin, Burgers, and of course 3K
Old Apr 1, 2012 | 10:21 AM
  #43
brenner's Avatar
glad you got it worked out.
it is nice when it turns out to be something simple like that. cheers.
Old Apr 1, 2012 | 06:31 PM
  #44
3K's Avatar
3K
Awesome, glad you got it sorted out. I know, who would have thought spark plugs. I was scratching my head for 2 months trying to get my fuel cut issue fixed. I made a lot changes to my rom, changed parts. Nothing. Googled fuel cut, most of the issues dealt with boost cut, load cut. But a couple said to change the spark plugs, tried it. Well whadda ya know. Coulda saved me alot of money. ha ha
Old Apr 3, 2012 | 05:30 PM
  #45
wizzo 8's Avatar
Well the problem is back. Since the problem got fixed with new spark plugs obviously its an ignition issue. I bumped my spark plug gap from. 023 to. 021. Hopefully that takes care of it.
