Ful cut but why??
Old Apr 4, 2012 | 02:03 AM
  #46
burgers22's Avatar
Have a look at the DIY COP set up people have been building. Pretty easy to do and look cool as well.
Old Apr 4, 2012 | 04:20 AM
  #47
wizzo 8's Avatar
I already have a spoolinup cop setup.
Old Apr 6, 2012 | 07:02 PM
  #48
wizzo 8's Avatar
Ok so I finally figured out what I thought was "fuel cut". The spark plugs helped for a couple pulls because I was running too rich after 7k rpm. Took me a while to figure it out but yea I leaned it out after 7k and all is fixed. Hopefully this helps out other tuners and self tuners.
Old Apr 7, 2012 | 04:37 AM
  #49
Benja's Avatar
How rich were you running? Sub 10.5's?
Old Apr 7, 2012 | 05:48 AM
  #50
wizzo 8's Avatar
Not even close which is why I never thought it could be that. It was mid 11s. This is with e90. Bumped it to about 12 and its all good now. So for spool up I have it at 12.5 and for the rest of the pull its 12. I think my lc1 may be reading a bit leaner than it really is though.
Old Apr 7, 2012 | 05:58 AM
  #51
tscompusa's Avatar
mid 11's wont cause misfire on ethanol.. even 10 flat wont. ethanol's RBT is far lower then gasoline.
test your o2 sensor asap.. and proceed with caution.
Old Apr 7, 2012 | 06:01 AM
  #52
tscompusa's Avatar
oops forgot to post how to test your sensor;
http://www.youtube.com/watch?v=1mb4VmDd0ao
Old Apr 7, 2012 | 06:27 AM
  #53
wizzo 8's Avatar
Hmm. I understand what you are saying but ever since I adjusted fuel its been good. I actually have 2 wideband sensors. My lc1 for logging and a autometer with gauge. I think my autometer is more accurate and reads a Tad richer. Ill watch the how to when I get home and do the test. I'm just happy the problem is gone.
Old Apr 20, 2012 | 04:18 PM
  #54
wizzo 8's Avatar
Originally Posted by tscompusa
if you try to lift shift with NLTS activated the car will freak out inbetween shifts.
dont ask me how i know.
Originally Posted by merlin.oz
I dont think you mentioned what coil setup you have, but what you are describing is fuel-cutting, not plug/coil problems. I think tsc is on money re NLTS.
Well I after messing with the fuel and spark plugs and thinking it was fixed it wasn't. It did help but not 100%. I disabled NLTS and after a couple weeks of no fuel cut well I can officially say its fixed. I enabled it and fuel cut. So you guys were right. So my next question is am I SOL for running NLTS? Is NLTS only for lower HP cars
That would really suck if I couldn't use this great feature.
Old Apr 20, 2012 | 10:13 PM
  #55
C6C6CH3vo's Avatar
If IDC reads 0, it is commanded to shut fuel. Where is your left foot while this is happening?
Old Apr 21, 2012 | 05:47 AM
  #56
wizzo 8's Avatar
Off the clutch. It is very possible that maybe since its getting close to redline that I may be covering the clutch at those rpms without me even noticing.
Old Apr 21, 2012 | 06:53 AM
  #57
Evo8RLK's Avatar
Smile
Originally Posted by wizzo 8
Well this was the problem. for 3K. I couldnt believe it. I installed some iridium plugs and now it pulls to redline without any problems. I know what it feels like when the gap is too big and it breaks up up top but this was like I was hitting a wall. Im also not sure why this would cause my afrs to sky rocket when it happened. You would think it would go rich. Well either way its fixed. Thanks for all the help Raptord, Tcomp, Merlin, Burgers, and of course 3K
Just in case you were still wondering, it would show lean because the oxygen sensor or wideband sensor is picking up all the oxygen that didn't get ignited with the fuel. Basically its bot exhaust just oxygen and fuel. Hope that made sense
Boosted Tuning
Aug 26, 2023 10:14 PM
sebas-chan
Apr 25, 2018 06:03 AM
isnake
Apr 9, 2017 02:01 AM
butte
Nov 12, 2015 04:23 PM
