How do I enter a hex value with a decimal point?
Old Mar 31, 2012 | 11:20 AM
okevolutionVIII's Avatar
I searched for hours last night and today and can't get an answer. On my injector battery voltage latency table, the 11.7v-18.6v tables cannot be adjusted where I need them to be. It'll only go up or down in 1ms increments and can't be adjust using 1% increments like I used on the others so I'm trying to enter the values manually.
So first up, I'm trying to set the 11.72v setting to .706ms. What formula would I use to enter .706 as a hex value?
Old Mar 31, 2012 | 11:27 AM
JohnBradley's Avatar
Smallest changes are 0.024 ms. You need to adjust the latency scaling value from 1ms increment to 0.024 increments. Or just manually enter a number such as .706 and see what the closest it gets is.
Old Mar 31, 2012 | 11:33 AM
Yeah, I can't just enter 0x.706 though. I need to know how enter a decimal in there. Like I said, I can't change the values using + or - on the values from 11.7v-18.6v tables. It worked fine on the other 3.
Old Mar 31, 2012 | 12:00 PM
todd6027's Avatar
change the others first then go back to .706
Old Mar 31, 2012 | 12:15 PM
The hex number is going to reflect each change in a 0.024 increment is what I mean. Your choices in the stock software are 0.696 or 0.720 which is close enough trust me.
Old Mar 31, 2012 | 12:47 PM
Already did this. The only changes I'm able to make anywhere close is 0.000 to 1.008 on the last 4 (higher voltage) tables. I'm not worried if it's .050ms off, I'm just not able to adjust it in the .024ms increments, just 1.008 increments.
I need to know how to put a decimal in the hex value. I don't care if its .100 off, I just can't adjust it using the "Increase/decrease 1%" like I did on the others, it won't let me.
Old Mar 31, 2012 | 01:12 PM
211Ratsbud's Avatar
Manually enter the decimal of your choice. It will snap to the closest accepted value. Takes a little bit of tryingbut thats how i do it.
Old Mar 31, 2012 | 01:22 PM
It usually says something like "Hexidecimal value invalid" or something along those lines.
Old Mar 31, 2012 | 02:22 PM
Raptord's Avatar
It's not a hex value you're entering; you should NOT be prefixing the value with 0x.
Old Mar 31, 2012 | 06:40 PM
That explains it, I guess I've been following instructions more than I should. I'll give it a try when I get back to my laptop, thanks.
tephra
57
Dec 23, 2023 09:14 AM
mrfred
Dec 15, 2022 11:13 AM
Hiboost
15
Jan 10, 2016 10:15 PM
mrfred
Nov 25, 2011 09:51 PM
Appauldd
Aug 28, 2010 06:47 PM
