Evoscan auto-disconnect
Old May 1, 2012 | 12:37 PM
fabiangt79's Avatar
I tried to datalog on my Subaru, at first it connects find but when i tired to do a full power run it auto-disconnects after 4K rpm.Did a few times and tried another 2 Subaru same thing happens.
I tried all my USB ports on my computer same thing happens and even tried the 2.7 evoscan version.
This is my error message,
Info: Initialize Vehicle ECU...
Info: Starting Subaru SSMII Init...
Info: Received 57 Data Bytes.
Info: ECU ID: A2101104
Info: Connection successful...
Error: FTDI Read Error - 4
Info: Datalogger Ended.
Anyone encounter this issue before and have solutions to resolve it?
Old May 1, 2012 | 10:48 PM
philr8's Avatar
You wasting your time with Evoscan on a Subaru, use Romraider instead
Old May 2, 2012 | 03:16 AM
fabiangt79's Avatar
I have seen other tuners use evoscan to log with success.
I am sure it be able to log, I used romraider for my 06 legacy gt but it will not connect?
How am I able to do logging for my car, only tried evoscan that can connect the logging but will disconnect after I do full load.
Can someone advise or guide me how to resolve this issue?
Thanks!
Old May 2, 2012 | 04:15 AM
Daluv's Avatar
+1
romraider + fast poll enabled for subaru logging.
Mart
Old May 2, 2012 | 09:38 AM
fabiangt79's Avatar
Originally Posted by Daluv
+1
Mart
Since I already paid for the licsense, I might as well resolve the issue.
I be using evoscan on evos too.
I remembered that I use the 2.0 cable to log a Evo 6 it works fine Only after switching to 1.3U cable then this happens.
Could it be the cable issue?cable is brand new and 1st time using
Old May 2, 2012 | 09:39 AM
Daluv's Avatar
evoscan works fine on evos.
use romraider to validate your cable.
Mart
Old May 6, 2012 | 09:54 AM
fabiangt79's Avatar
Mart
Cable works fine with romraider, evoscan still hangs.
Anyone can help?
Old May 6, 2012 | 12:20 PM
evoscan's Avatar
Silver Sponsor
Anyone can help?
Maybe your laptop has HP HDD protection turned on? the g forces in some laptops pause the harddrive. check you have laptop power settings on max performance, and try a few runs with hdd protection off. if it makes no difference then turn it back on.
Old May 8, 2012 | 07:42 AM
fabiangt79's Avatar
Logging Data is out, Load is always at 100%
Hi Hamish,
I have added you to my Skype contacts.Today i tried to log again from my 06 legacy and it work without disconnecting.
I just log 7 items in the data and the run was stable.
Now,my log has some problems.
My engine load always reads 100, and i am unable to log injector duty cycle.There is no option for me to tick, do i have to add in?
I still cannot log the mainfold absolute pressure as BAR, because psig reads way out.My car is only boosting 1.2 bar but i log 27 psi which is 1.8 bar.
Any ideas to resolve?
Fabian
Old May 8, 2012 | 07:45 AM
fabiangt79's Avatar
A datalog of my car
Old May 8, 2012 | 07:51 AM
fabiangt79's Avatar
I am thinking, does the problem lies with the rom settings?I have opened the file and these are the data items for SSMII.
Favorites#SSMII=Default List
Favorites#SSMII_DisplayCheckedOnly=False
Favorites#SSMII_Count=0
DataItems#SSMII_EngineLoad=Y
DataItems#SSMII_CoolantTemp=Y
DataItems#SSMII_AirFuelCorrection1=N
DataItems#SSMII_AirFuelLearning1=N
DataItems#SSMII_AirFuelCorrection2=N
DataItems#SSMII_AirFuelLearning2=N
DataItems#SSMII_ManifoldAbsolutePressure=Y
DataItems#SSMII_RPM=Y
DataItems#SSMII_VehicleSpeed=N
DataItems#SSMII_IgnitionTiming=Y
DataItems#SSMII_IntakeAirTemp=N
DataItems#SSMII_Mass_Air_Flow=N
DataItems#SSMII_TPS=Y
DataItems#SSMII_FrontO2Sensor1=N
DataItems#SSMII_RearO2Sensor=N
DataItems#SSMII_FrontO2Sensor2=N
DataItems#SSMII_BatteryVoltage=N
DataItems#SSMII_AirFlowSensorVoltage=N
DataItems#SSMII_ThrottleSensorVoltage=N
DataItems#SSMII_DifferentialPressureSensorVoltage= N
DataItems#SSMII_FuelInjection1PulseWidth=N
DataItems#SSMII_FuelInjection2PulseWidth=N
DataItems#SSMII_KnockCorrection=Y
DataItems#SSMII_AtmosphericPressure=N
DataItems#SSMII_ManifoldRelativePressure=Y
DataItems#SSMII_PressureDifferentialSensor=N
DataItems#SSMII_FuelTankPressure=N
DataItems#SSMII_COAdjustment=N
DataItems#SSMII_LearnedIgnitionTiming=N
DataItems#SSMII_AcceleratorOpeningAngle=Y
DataItems#SSMII_FuelTemperature=N
DataItems#SSMII_FrontO2Heater1Current=N
DataItems#SSMII_RearO2HeaterCurrent=N
DataItems#SSMII_FrontO2Heater2Current=N
DataItems#SSMII_FuelLevel=N
DataItems#SSMII_PrimaryWastegateDutyCycle=N
DataItems#SSMII_CPCValveDutyRatio=N
DataItems#SSMII_TumbleValvePositionSensorRight=N
DataItems#SSMII_TumbleValvePositionSensorLeft=N
DataItems#SSMII_IdleSpeedControlValveDutyRatio=N
DataItems#SSMII_AirFuelLeanCorrection=N
DataItems#SSMII_AirFuelHeaterDuty=N
DataItems#SSMII_IdleSpeedControlValveStep=N
DataItems#SSMII_NumberExGasRecircSteps=N
DataItems#SSMII_AlternatorDuty=N
DataItems#SSMII_FuelPumpDuty=N
DataItems#SSMII_IntakeVVTAdvanceAngleRight=Y
DataItems#SSMII_IntakeVVTAdvanceAngleLeft=Y
DataItems#SSMII_IntakeOCVDutyRight=N
DataItems#SSMII_IntakeOCVDutyLeft=N
DataItems#SSMII_IntakeOCVCurrentRight=N
DataItems#SSMII_IntakeOCVCurrentLeft=N
DataItems#SSMII_AirFuelSensor1Current=N
DataItems#SSMII_AirFuelSensor2Current=N
DataItems#SSMII_AirFuelSensor1Resistance=N
DataItems#SSMII_AirFuelSensor2Resistance=N
DataItems#SSMII_AirFuelSensor1=N
DataItems#SSMII_AirFuelSensor2=N
DataItems#SSMII_GearPosition=N
DataItems#SSMII_AFSensor1HeaterCurrent=N
DataItems#SSMII_AFSensor2HeaterCurrent=N
DataItems#SSMII_RoughnessMonitorCylinder1=N
DataItems#SSMII_RoughnessMonitorCylinder2=N
DataItems#SSMII_AirFuelCorrection3=N
DataItems#SSMII_AirFuelLearning3=N
DataItems#SSMII_RearO2HeaterVoltage=N
DataItems#SSMII_AirFuelAdjustmentVoltage=N
DataItems#SSMII_RoughnessMonitorCylinder3=N
DataItems#SSMII_RoughnessMonitorCylinder4=N
DataItems#SSMII_ThrottleMotorDuty=N
DataItems#SSMII_ThrottleMotorVoltage=N
DataItems#SSMII_SubThrottleSensor=N
DataItems#SSMII_MainThrottleSensor=N
DataItems#SSMII_SubAcceleratorSensor=N
DataItems#SSMII_MainAcceleratorSensor=N
DataItems#SSMII_BrakeBoosterPressure=N
DataItems#SSMII_FuelPressureHigh=N
DataItems#SSMII_ExhaustGasTemperature=N
DataItems#SSMII_ColdStartInjector=N
DataItems#SSMII_SCVStep=N
DataItems#SSMII_MemorisedCruiseSpeed=N
DataItems#SSMII_ExhaustVVTAdvanceAngleRight=Y
DataItems#SSMII_ExhaustVVTAdvanceAngleLeft=Y
DataItems#SSMII_ExhaustOCVDutyRight=N
DataItems#SSMII_ExhaustOCVDutyLeft=N
DataItems#SSMII_ExhaustOCVCurrentRight=N
DataItems#SSMII_ExhaustOCVCurrentLeft=N
Can anyone advise or help me edit the correct data for logging?
Fabian
Old May 8, 2012 | 12:15 PM
philr8's Avatar
Hey Buddy
Save your self the grief and time use "ROMRAIDER"
Bewstzalot
Jul 7, 2017 01:35 PM
Icem@n
Nov 12, 2015 07:35 AM
mike86
Jan 20, 2010 07:04 PM
Go_Lancer_Go
Jan 4, 2010 09:18 PM
Evo_Matt
Mar 18, 2008 04:36 AM
