How do i Log my Load @ Evoscan Live Map Tracer?
Old Aug 30, 2012 | 10:12 PM
jameswwt's Avatar
Hi,
can someone show me on how to log or view my actual Load%on Evoscan Live Map Tracer?
Ive been trying to check on which load my car is hitting while WOT or when its knock.
Thanks and sorry for the noob quest.
Old Sep 1, 2012 | 02:49 AM
jameswwt's Avatar
Hi anyone mind to guide me...
Thanks
Old Sep 1, 2012 | 03:20 AM
HsamehH's Avatar
with v2.9 main screen select the parameters you want to log and then select you will select graph & map tracer then you will select start datalogger i(if i remember well)it will start logging and gauges will appear,just connect it and you will figure it out pretty easy.
Old Sep 1, 2012 | 06:51 PM
jameswwt's Avatar
I still can get the load log and attach is a preview of my selection in map tracer
Attached Thumbnails How do i Log my Load @ Evoscan Live Map Tracer?-map-tracer.jpg
Old Sep 1, 2012 | 07:58 PM
07EvoIX's Avatar
Map tracer is the first tab (Grid). Panel #1 references the Grid tab
The alst tab is right at the bottom of the screen on the right side.
cheers
Old Sep 2, 2012 | 05:50 AM
jameswwt's Avatar
cheers
Hi 07Evo,
thanks for sharing but what i mean is i cant get any figures after every logs i done on the Panel#1 RMP vs LOAD%?
My main intention is to know which load im hitting on my map.
Thanks
Old Sep 2, 2012 | 07:06 PM
domyz's Avatar
Did you change the load log name in evoscan parameters (edit data items, log reference...) ?
Old Sep 3, 2012 | 12:46 AM
jameswwt's Avatar
Hi Domyz,
im not sure but how could i check it and what is the default setting name?
Thanks
Old Sep 3, 2012 | 02:53 AM
07EvoIX's Avatar
post up a copy of your log so we can see what load you are logging and if the file works on our computers.
cheers
Old Sep 3, 2012 | 07:19 AM
domyz's Avatar
Yes post your log we'll look at it for you
babaz7
Jan 6, 2022 05:41 PM
4b11slayer
Nov 10, 2016 07:57 PM
Burnhad91
Jun 2, 2016 06:35 AM
Icem@n
Nov 12, 2015 07:35 AM
kwboost
May 12, 2014 06:29 PM
