RPM based A/F issue Stock ECU only
Old Oct 1, 2012 | 10:20 AM
Tony.b's Avatar
Originally Posted by 07EvoIX
not sure of any of this will help you, but have you tried
- dirty injetors
- injector latency
- injector scaling
- sprak plugs
- plus leads >>> unless you are running a COP kit
cheers
I have tried all of the above. Thanks for the suggestions.
Tony
Old Oct 5, 2012 | 07:33 PM
Tony.b's Avatar
I put the maf and stock injectors back on the car and it ran fine. That was the first good thing that had happened since I started working on this problem. So that lead me down the path to getting it figured out. The omni 4 bar map sensor that I had bought brand new was bad. The crazy thing is it did the same thing on the aem 5 bar which is why I bought the 4 bar. Just a guess but the only reason I can think of why both map sensors worked fine on the aem was because of aem's map filter. Maybe it was such a small area of the sensor that was bad the map filter on the aem was blocking it or something. It's been a long road trying to get this thing figured out. I am just glad the car is running correctly now on the stock ecu.
Thanks for the help and suggestions.
Tony
austin_davee
Dec 17, 2016 07:19 AM
MagicManRed
Oct 25, 2011 10:57 PM
Frasch
29
Dec 25, 2010 12:56 PM
RedLanEVO
AEM EMS
Oct 1, 2008 08:53 AM
hackish
65
Sep 27, 2008 10:55 AM
