EGR issues
Old Sep 13, 2012 | 07:11 PM
jedibow's Avatar
EGR issues
Hello all,
I removed my EGR valve, EVAP solenoids (completely removed meaning unplugged), vacuum lines, and installed a block off plate. I left the the FPR solenoid installed with vacuum lines and plugged in.
After I removed the the emissions items I started the car up and it idled fine, took it for a ride to check everything, and I was experiencing 9 counts of knock whenever I would apply any load to the car at all. The ECU would pull timing to no avail, the knock count would continue.
I reinstalled all the lines and emissions items and the car runs great again.
What did I do wrong?
2003 Evo VIII, tephra version 7 94170015 ROM. I disabled all the perphery bits according to the EVAP removal how to. https://www.evolutionm.net/forums/ev...-canister.html No check engine lights.
Thanks you for your assistence,
George
Old Sep 14, 2012 | 02:20 AM
foxbat's Avatar
Was that knock audible? Perhaps you left something loose after removing EGR, rattling around, causing a phantom knock.
Old Sep 14, 2012 | 12:17 PM
jedibow's Avatar
No audible knock at all, I didn't hear any rattling either, maybe I will remove the emissions equiptment again and setup DETCANs to be sure. I did zip tie all harnesses away, and I actually removed all the lines and solenoids so I don't think anything would rattle.
Thank you!
fostytou
359
Oct 23, 2025 09:54 AM
fireroasted
Dec 17, 2013 04:41 PM
fostytou
Oct 18, 2009 08:53 PM
fixem2
Aug 20, 2009 03:23 PM
EvoIXMR
Nov 7, 2008 06:21 PM
