EGR solenoids (quick question!!)
Old Oct 8, 2012 | 01:51 PM
4g63evoeight's Avatar
hey guys if you no longer have the EGR system can you just remove the solenoids or do you have to leave them plugged in?
Old Oct 8, 2012 | 02:04 PM
211Ratsbud's Avatar
They can be removed with proper disabling of the system in the rom
Old Oct 8, 2012 | 02:08 PM
Ev0ikon's Avatar
Unplug and clean up the hoses. Patch the ECU if you won't want the code/light.
Old Oct 8, 2012 | 04:36 PM
fireroasted's Avatar
I removed all the patched the ROM. Haven't had a code once I figured it all out. You will have 3 connectors left unplugged that are on the wiring harness. I taped my shut and together and placed out of the way.
Old Oct 8, 2012 | 09:34 PM
Sorry worded it wrong. I have it turned off via tephra v7. Just asking if you can physically remove the solenoids and leave them unplugged.
Old Oct 8, 2012 | 09:47 PM
Well, OK, yup. same answer. I don't use tephra, but I have the perish stuff that addresses the solenoids and their checks turned off in the ROM. (That's essentially the same thing).
And I have all the solenoids out of the car with all the remaining plugs, that are attached to the wiring harness taped up.
The only one that demanded some understanding was the FPR, and its function, as I was taught, is just for start up. Didn't have a negative impact on my car though.
fostytou
359
Oct 23, 2025 09:54 AM
05evoGSR
For Sale - Miscellaneous Automotive
Jul 9, 2014 08:33 PM
aggieEVO
Jan 16, 2013 05:18 PM
4g63evoeight
Jun 11, 2012 11:46 AM
MagnumVP
Lancer Engine Tech
Oct 27, 2011 03:11 PM
