Timing Issue
Old Oct 17, 2012 | 11:05 PM
tjac357's Avatar
Timing Issue
I've tuned my IX using ecuflash. And one of my friends recently bought an VIII which was supposedly tuned before. However the car was running very lean so he asked me to look at his tune. After making adjustments to the fuel map I looked at the timing map and was shocked with what I saw. I have no idea if this is just some weird way to do timing or if it is just really bad. Looking for some advice if this tune should just be thrown out and started from scratch. Mods are, intake, tbe, walbro 250, 272 cams, stock turbo.
Sorry for dropbox link, photobucket was killing the image quality.
https://www.dropbox.com/s/ogod9re89h...timing%202.tif
Thanks for the help.
Old Oct 18, 2012 | 07:35 AM
Spec-Ops1's Avatar
What were you shocked about?
Old Oct 18, 2012 | 07:58 AM
tjac357's Avatar
All the ignition advance in the idle region of the map.
Also I meant ignition not timing it was just a long day.
Old Oct 18, 2012 | 08:06 AM
Raptord's Avatar
Timing and ignition are used interchangeably here.
Timing map doesn't look completely out of normal to me, I don't see why you'd start from scratch. Do your friend's car have big cams? Would explain the added timing at idle.
Old Oct 18, 2012 | 10:23 AM
Spec-Ops1's Avatar
Possibly added timing (the corner of 24's) to catch a low idle situation...
Old Oct 18, 2012 | 11:25 AM
tjac357's Avatar
It does have large cams. I was just wondering if that much added timing was normal.
Old Oct 18, 2012 | 11:52 AM
wazzelby's Avatar
I gotta say, having between 15-20 timing at idle does seem pretty damn aggressive!! As for the rest, no one can say if there's too much timing without comparing it to a log. Some cars do better with timing than others - plus the mods and supporting parts play a huge factor.
Old Oct 19, 2012 | 01:28 PM
Boostin_AWD's Avatar
Id say that seems a little high at idle. What 272's are they? Something with a low lift like bc or hks wouldnt need nearly that much timing to idle smooth I'd assume. Im slightly confused on the load values...? 14 point jumps after 100 load all the way up to 380?? I could be wrong but I doubt a stock viii is getting anywhere near there. If it were me I'd rescale the load and work with getting rid of the blockyness of the map.
chamelieon
33
Mar 3, 2015 05:22 PM
giumela
For Sale - Wheels / Tires
Aug 8, 2014 08:54 PM
honki24
For Sale - Cars For Sale
17
Jul 27, 2014 03:38 PM
tjac357
Feb 11, 2013 07:39 PM
DsmSpeed
Jan 13, 2013 08:59 AM
