dynotech ecu switch help!
Old Oct 22, 2012 | 08:31 PM
Dynotech Tuning's Avatar
Didn't you go to the website link supplied with the harness?
www.dynotech-tuning.com/instructions.zip
Old Oct 23, 2012 | 06:50 AM
Tmosser's Avatar
Ya.. But since the pin broke off and the black tape isnt on idk what's what.
Old Oct 23, 2012 | 07:10 AM
There are only 3 wires. Eliminate the one that the pin broke off of and you are left with 2 remaining wires. One has a white stripe. That's the positive and the remaining wire is the negative ground wire. Connect these two wires properly first to ensure the red LED comes on with the switch and the ignition in the ON position. It seems odd that you received a harness, not only with no instructions but also the black marker not on the ground wire. It seems odd. Did you purchase this harness used??
Old Oct 23, 2012 | 11:43 AM
Tmosser's Avatar
No i bought it at map the black mark was on the ground, but since it wasnt working i cut the wires off from my harness and i forgot to mark the ground again and like i said the wire came out of the pin so i forgot what wire went to a pin since i have to buy a new one now.
Old Oct 23, 2012 | 12:02 PM
Ah,makes sense now. If you want to send it back to me, I can test the harness and install a new pin and re-mark the ground wire for you. If you mix up the ground wire and ECU pin wire, it will fry the circuit.
Our mailing address is on our website at http://www.dynotech-tuning.com/contact.html
Just put ATTN:Jamie on the package and I can get it back in the mail the same day for ya.
-Jamie
Old Oct 23, 2012 | 12:17 PM
Tmosser's Avatar
Awesome will mail it out Tomorrow!
Thank you Jamie
Old Oct 24, 2012 | 11:28 AM
Tmosser's Avatar
Shipped via usps will come in a pretty red/white stripe christmas padded envelope. Lol!
Local post office didnt have any reg packages.
If you can extend the wires as well id appreciate it, i didnt realize i cut them so short :/
kittttt
Apr 5, 2014 11:43 AM
JHS VIII
Jan 20, 2012 01:42 PM
oldwheelieguy
Dec 6, 2011 08:11 PM
EvoIXMR
Aug 12, 2008 10:12 PM
