Weird Load # at WOT & Stuttering
Old Nov 14, 2012 | 09:04 AM
  #31
evo8426's Avatar
In EvoScan your request ID is 41 for 1byte load. You need to adjust the MUT table at that location, MUT41 from 6A9B to 0x840B. You can only log 1byte load if you are using a Tephra V5.10 rom and higher. Hope this helps!
Add this to your scaling in the XML file.
<scaling name="1bytefactor" units="units" toexpr="x/((32/10)*100)" frexpr="x*((32/10)*100)" format="%.1f" min="1" max="2" inc="0.1" storagetype="uint16" endian="big"/>
Add this part lower in the XML past the scaling section.
<table name="2byte to 1byte Load Factor" category="Miscellaneous Tephra Mods" address="48260" type="1D" scaling="1bytefactor"/>
</table>
Old Nov 14, 2012 | 09:20 AM
  #32
10isace's Avatar
Originally Posted by 211ratsbud
2 byte to 1 byte conversion factor. It's actually a hardwired 2 byte formula that is divided by the factor you set then logged and multiplied by the factor in your evoscan. It's not technically a one byte load. That's why they need to be the same number
This makes sense. I was trying to simplify it for myself.
Originally Posted by fireroasted
OK thanks. I will log that tomorrow. Tonight I couldn't get time,as I also have the upgrade you have in your sig. The Britax special. I owe several responses to other threads folks are helping me on my cruise knock.
I am embarrassed to ask but where in my rom or how do I modify the 1byte value like I do in EvoScan? the 1.2 to 1.5. it must be so obvious I am missing it.
Britax is the best! Nothing but the best for those little guys
In my ROM it's under Miscellaneous Tephra Mods, 2 byte to 1 byte Load Factor. Click on the # in the window, hit the = button, type in 1.5, hit enter, save, flash.
In EvoScan right click on Load 1 Byte, hit edit, left click on Load 1 byte, change Eval to 1.5*x, hit ok, close.
Good Luck!
Old Nov 14, 2012 | 09:59 AM
  #33
fireroasted's Avatar
Maybe we are the root of it for me. I am not using a tephra ROM.
Old Nov 14, 2012 | 10:13 AM
  #34
kailoma679's Avatar
Originally Posted by 10isace
I'm getting stuttering/hesitation at about 3900 RPM under WOT. It's right around 29psi and up to 32psi that it does this. According to the logging it looks like I'm at 350 load then it goes down to 5 or 1 load. Is this because I may be getting to 360 load and my maps only go up to 350?
I've already adjusted my fuel cut load to 638. It also may be my plugs (about 5k miles on copper plugs).
I had a very similar problem in my IX. I found out that my TPS pins were loose and was loosing signal as rpm increased cause of the vibration.. So I just pulled the pins out and with a small pick I depressed the tab in each pin so it would stay in contact... Try that out and see...
Koroshiya
34
Oct 20, 2017 07:15 AM
Kody Mills
10
May 13, 2017 12:52 AM
Danial81
Lancer Troubleshooting
Sep 8, 2016 09:31 PM
edsct9a
Apr 21, 2016 11:31 AM
stunt2
May 25, 2012 01:46 PM
