knock after oem DV install ?
Old Nov 5, 2012 | 11:35 AM
stunt2's Avatar
went from vta bov back to oem metal diverter valve and experiencing some knock counts. haven't logged yet but when cruising if I apply part throttle lightly, cel begins to flash fast (more than 6 counts of knock) untill I lift off.
and also when doing low rpm wot pulls it flashes during spool up but with slow flashes this time. before had zero issues with vta bov.
changing bov needs retune ? or there's some other issue
Old Nov 5, 2012 | 11:50 AM
foxbat's Avatar
You must be hitting higher loads than before, your load curve had probably shifted. Max boost is probably a bit higher too.
Old Nov 5, 2012 | 11:56 AM
stunt2's Avatar
why that ? is it common with dv's ?
Old Nov 5, 2012 | 12:04 PM
foxbat's Avatar
A while ago, I removed my HKS BOV & installed the stock metal, boost went up by 1.5psi. The stock BOV must have a stiffer spring. If you invert or cancel the BOV, boost will even go higher.
thedru13
Nov 3, 2014 08:58 AM
AutoXer
Jun 28, 2012 08:31 AM
stealthMR
Jun 6, 2011 06:56 PM
cij911
Aug 7, 2007 04:42 AM
jcnel_evo8
Oct 1, 2003 05:42 PM
