A bunch of load calculation related maps
Had a little time today so gave the 3xMAP tables use actual MAP, not averaged digging a go. I haven't tried any of these so as always proceed with caution and hopefully tephra wouldn't mind confirming.
Enjoy!
52680024:
55570006:
56890013:
58010005:
59580004:
Enjoy!
52680024:
Code:
<table name="3xMAP tables use actual MAP, not averaged 0xC78A -> 0xC6DE" category="Misc" address="62a2a" type="1D" scaling="Hex16"/>
Code:
<table name="3xMAP tables use actual MAP, not averaged 0xC79E -> 0xC6F2" category="Misc" address="62c84" type="1D" scaling="Hex16"/>
Code:
<table name="3xMAP tables use actual MAP, not averaged 0xC7CE -> 0xC722" category="Misc" address="63474" type="1D" scaling="Hex16"/>
Code:
<table name="3xMAP tables use actual MAP, not averaged 0xC7D6 -> 0xC72A" category="Misc" address="634b2" type="1D" scaling="Hex16"/>
Code:
<table name="3xMAP tables use actual MAP, not averaged 0xC7DA -> 0xC72E" category="Misc" address="63446" type="1D" scaling="Hex16"/>
Are you experiencing this as well?
Would the 3xMAP current readout patch be better with get scaling right or would it be too touchy?
Also for the TPS LiftOff patch have weird effects if you put anything above 0.4% in the Load Multplier End table?
Enjoy!
55570006:
Enjoy!
55570006:
Code:
I am getting 0xC6F4
Enjoy!
55570006:
Enjoy!
55570006:
Code:
I am getting 0xC6F4
Tephra, can you confirm?
Yeah, I'm 4 years late...
Can anyone please help me find the tables bellow in my 56950008 with tephramod v3?
ECT Compensation for Load
MAF IAT Compensation for Load
Baro Compensation for Load
Load multiplier when TPS increased by %
Load multiplier end when TPS decreased by % (hysteresis)
Load multiplier when TPS Increasing - MAP High Load Multi
Load multiplier when TPS steady - MAF/MAP Low Load Multi
Load multiplier - TPS steady Decay Rate
Load Increase/Decrease threshold" category="Load" address="53ca6" type="1D" scaling="Loadify_x50"/>
Load Increase/Decrease divider (ie 1 is biggest)" category="Load" address="530e8" type="1D" scaling="uint16"/>
Load Increase/Decrease multiplier (ie 1 is smallest) #1" category="Load" address="530e4" type="1D" scaling="uint16"/>
Load Increase/Decrease multiplier (ie 1 is smallest) #2" category="Load" address="530e6" type="1D" scaling="uint16"/>
Load RampUP Rate
Load RampDOWN Rate
Load Ramp Rate #1 (Load > 75)
Load Ramp Rate #2
Load Ramp Rate #3
Load Ramp Rate #4
TPS Liftoff Baro to Load patch #1
TPS Liftoff Baro to Load patch #2
TPS Liftoff Max Load patch
Load RampUP Rate
Load RampDOWN Rate
Load Ramp Rate #2
Load Ramp Rate #3
Load Ramp Rate #4
(this is with 1 and 1 in the tps increase/decrease fields)
