Pop's & Bang's Map...Is it BAD?
Old Nov 20, 2012 | 09:54 AM
Biggy VIII's Avatar
Originally Posted by dolphin888
Interesting idle timing. How does it feel when engine is warming up?
just fine. I run 20* at idle on my own car. you can find my map in Lets see your fully tuned timing maps thread.
Old Nov 20, 2012 | 12:04 PM
dolphin888's Avatar
Originally Posted by Biggy VIII
just fine. .
That car has AFR set at 15.4 as well, is it in OL? What actual AFR you are getting?
Old Nov 20, 2012 | 12:09 PM
wjamyers's Avatar
too cool !
Old Nov 20, 2012 | 12:15 PM
Biggy VIII's Avatar
That car is fully in OL. WBO2 reads ~14.5 at idle.
Old Nov 20, 2012 | 12:26 PM
dolphin888's Avatar
Have you tried running with lower timing (up to 10deg) at idle? I am curious how huge timing difference affects AFR in OL with your setup. BTW it's on MAF or SD?
Old Nov 20, 2012 | 12:35 PM
Biggy VIII's Avatar
I have not tried anything on that car as it is not my. Just a car of my friend. It is on MAF.
As for my setup.. I was trying timing from 5* to 25* at idle and never noticed major difference in AFR. It is on MAF too. For now I am at 20* at idle, and 14.7 in fuel map is matching actual average AFR on my LC-1 in OL. MAF is not rescaled, injectors are dialed in using 812 scaling and latency from ID table.
Old Nov 20, 2012 | 12:43 PM
dolphin888's Avatar
I have tried to play with idle timing as well, it doesn't give huge difference in AFR, but it helped me smooth my idle with aftermarket cams for sure.
Old Nov 20, 2012 | 12:45 PM
Lancer_Evo_8's Avatar
@ Biggy VIII
Are you not scared to drive with your posted ignition and afr map?
How long you already drive this setup?
No problems with the idle?
Old Nov 20, 2012 | 12:53 PM
Biggy VIII's Avatar
Originally Posted by Lancer_Evo_8
@ Biggy VIII
No, not scared. Why should I?
Btw I have not posted MY AFR map anywhere yet. I have posted my timing map only in "Lets see your fully tuned timing maps" thread. The maps posted in this thread are not from my car.
My setup is constantly evolving for four years. I have never experienced any major problems so far.
Old Nov 20, 2012 | 12:57 PM
dolphin888's Avatar
No, not scared. Why should I? Btw I have not posted MY AFR map yet. I have posted my timing map only in Lets see your fully tuned timing maps thread..
I believe he saw your friends maps, although they look really well. Although I like less timing at spool up/overboost.
Old Nov 20, 2012 | 01:05 PM
Biggy VIII's Avatar
I like the strategy of having as much torque as possible irrespective of boost.
Old Nov 20, 2012 | 01:08 PM
dolphin888's Avatar
I like the strategy of having straight rods and no holes in my block irrespective of luck.
j/k
P.S. How many Nm?
Old Nov 20, 2012 | 01:12 PM
Biggy VIII's Avatar
j/k
My previous setup made 630nm of peak torque at 3900 rpm on stock block evo9 turbo +meth, and 590nm on ron98. And lived happy for 2,5 years (25000km) of daily driving and auto-x-ing. Straight rods, clean pistons, no holes in the block.
Then I decided to go 2.3.
Old Nov 20, 2012 | 01:13 PM
domyz's Avatar
I'm sure that you have more torque for each cell but if it takes twice the time to load the car, overall torque suffer. Area under the curve ftw
Old Nov 20, 2012 | 01:19 PM
dolphin888's Avatar
Impressive numbers.
Let's stop OT now:|
