88580014 Definition Clarification Needed
Old Nov 26, 2012 | 03:26 PM
07EvoIX's Avatar
Hi All,
When installing ECUFlash, the XML for 88580014 has the below 2 entries
<table name="Desired ISCV intial step position with AC off-Neutral" address="3d48">
<table name="Engine Temp" address="71ca" elements="8"/>
</table>
<table name="Target Minimum Idle" address="3d48">
<table name="Engine Temp" address="71ca"/>
</table>
can anyone advise what the correct tables/addresses are please?
cheers
Old Nov 26, 2012 | 05:30 PM
211Ratsbud's Avatar
Ill check in a couple hours if someone doesn't respond by then. Gotta get home
Old Nov 26, 2012 | 05:48 PM
211Ratsbud's Avatar
I have the same thing... Did u get the mr Fred iscv idle tables however because they superceed your current XML I believe
Old Nov 27, 2012 | 12:59 PM
07EvoIX's Avatar
im going through all of that now
cheers
Old Nov 27, 2012 | 09:28 PM
CDrinkH2O's Avatar
Originally Posted by 07EvoIX
Hi All,
</table>
</table>
cheers
You have bad XMLin 88580013.xml. It should be:
<table name="Desired ISCV intial step position with AC on-Neutral" address="3d70">
</table>
PPM
Apr 2, 2015 09:35 AM
mrfred
Dec 21, 2014 10:13 AM
NOMIEZVR4
Oct 26, 2009 10:36 PM
Mattjin
Oct 11, 2009 03:11 AM
Mattjin
May 9, 2009 08:40 PM
