What is the limit of stock Evo IX MAF ?
Old Mar 26, 2013 | 06:24 PM
merlin.oz's Avatar
I know of a few stroker Evos on stock MAF running over 40 psi no problem - you would be well advised to leave it in there.
Yes, you do need the load limit delete/double mods when pushing past load 320%, but that is not a problem.
Old Mar 26, 2013 | 06:30 PM
Anarchy99's Avatar
Originally Posted by KameloT
Would it be possible to tune GTX35 turbo on stock ecu and maf and what sort of power can I achieve with it ? The car is Evo IX JDM.
Thank you!
Old Mar 26, 2013 | 07:06 PM
tscompusa's Avatar
load limit before modding is cut off at 379 if i recall correctly. the maf is a thing of the past on these cars, or at least should be with larger turbo builds.
Old Mar 27, 2013 | 04:42 AM
kamelot-4's Avatar
Redid the 2-byte load and rpm, and see what will change in the log. By the way, the bar in the log also shows 0.3 units less than in reality.
Old Mar 28, 2013 | 01:46 PM
kamelot-4's Avatar
When the settings of the Kpa to load at the end of table 500-550, scaling of injectors 1949, table VE has a strong variation, from 80 at idle, up to 125 at 1 bar. At 1 bar лоад comes to 270, and the car moves at a very late ignition. Лоад 2 bytes in the atmospheric zone coincides with the numbers OMNI 4 bar, I can't understand the reason for the strong differences ...
Old Mar 28, 2013 | 02:01 PM
evo8426's Avatar
Without seeing your actual ROM it is going to be hard to diagnose your issue.
Old Mar 28, 2013 | 06:38 PM
kamelot-4's Avatar
Added firmware and lo
File Type: hex
Old Mar 29, 2013 | 01:00 AM
KameloT's Avatar
What's the right scaling on ID2000 at stock pressure of fuel? We have 1949 , because at 1624 too much fuel at xx. What's wrong ?
Thank you.
Old Mar 29, 2013 | 04:28 PM
merlin.oz's Avatar
try 1720
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
W06EMR
Jan 4, 2011 04:19 PM
OctaneBlueRA
Jan 12, 2010 05:36 AM
Done
10
Oct 23, 2009 12:35 PM
tkklemann
Mar 5, 2008 03:32 AM
