Need A LOT of SD help...
Old Dec 8, 2012 | 02:08 PM
  #31
btmboards's Avatar
problem I am having now is kind of a newbe issue but I havent needed to do it since I got the evo and first loaded on the tephra rom.
I cant remember how to create a new bin/hex file for it to pull a tune from. Right now everything I do is pulling from 88590015 but I need to make ecuflash pull from 88591715 xml instead so that I can open them up at the same time so that I can transfer my tunes over instead of just editing the one I am already using.
Old Dec 8, 2012 | 03:40 PM
  #32
211Ratsbud's Avatar
Call me tonight ill walk u thru a couple things
315 five 86 3010
Old Dec 8, 2012 | 03:54 PM
  #33
ExViTermini's Avatar
In for prank call stories.....
J/k
Old Dec 8, 2012 | 04:04 PM
  #34
btmboards's Avatar
315 five 86 3010
Thanks, I went through it a little round about way to get me where I need to be. I am transferring some of my tuned maps into it now and trying to get it dialed with all the right scaling. The big issue that is taking awhile is that I was mistaken and I didnt have the latest tephra V7. now I do though and should be ready for a flash and trial soon tonight.
By the time I get is ready I try it, It will be real late for you (since you are 3 hours ahead of me.) I will post up and shoot you a PM when I figure out when or if I need more help then we will go from there with a call if you are still available. Thanks a ton for the offer.
Old Dec 8, 2012 | 04:20 PM
  #35
211Ratsbud's Avatar
Yup np
Old Dec 8, 2012 | 04:54 PM
  #36
btmboards's Avatar
just went out to try and flash it. at about 45% complete, windows crashed and shut down my who computer and erased all the tuning changes i made in the entire rom. Luckly I was able to boot back up and flash to an older rom just to get the car OK again. Now I have to go back through and redo all my table and everything then go try again.
Old Dec 8, 2012 | 05:42 PM
  #37
btmboards's Avatar
Alright well I got it flashed so I have it running full V7 + SD now the way it is supposed to but my scaling is way off.
I do not have that kpa map scaling table you have in that picture. this is the closest I got so I dont know how to select the Omni 4bar
Old Dec 8, 2012 | 05:54 PM
  #38
211Ratsbud's Avatar
My windows crashes a lot while flashing and logging. did you get an IRQL blue screen dump?
Old Dec 8, 2012 | 05:58 PM
  #39
btmboards's Avatar
yep sure did, just did it once, fix some values and it when through perfect the next time.
Old Dec 8, 2012 | 06:12 PM
  #40
211Ratsbud's Avatar
ok ill show you the scaling to add to your 8859xml
Code:
<scaling name="kPa OMNI4barMAP" units="kPa" toexpr="x*0.4072" frexpr="x/0.4072" format="%.1f" min="0" max="450" inc="0.4072" storagetype="uint16" endian="big"/>
Old Dec 8, 2012 | 06:36 PM
  #41
btmboards's Avatar
cool thanks, but now ecuflash just decided it dosent want to pull any definitions from any of the right places. I am having so many computer issues, I am getting pissed as soon as I can get this crap fixed I should be able to actually do something.
Old Dec 8, 2012 | 07:01 PM
  #42
btmboards's Avatar
alright so I got my stuff fixed and can get into fine now but I just went to add the scaling to it but that def. isnt a table it is just a set of values. so how did you get the scaling table into ecu flash
Old Dec 8, 2012 | 07:12 PM
  #43
211Ratsbud's Avatar
Right click on your XML def preferably v7 and edit XML add that in save presto
Old Dec 8, 2012 | 07:40 PM
  #44
btmboards's Avatar
it adds a value into the xml but no table or values into ecuflash which is what is needed to make any changes to the ecu. could you take a screen shot of the table open just like I have above with the map table.
Edit:
Alright so I was able to find everything. That was a lot of code definition reading. So I already have that scaling. But even though I have that scaling in the definition but the scaling doesnt do anything unless it is applied inside a table.
According to this: https://www.evolutionm.net/forums/6744341-post2.html I am using the correct scaling already. Just doesnt seem like it trying to get is running worth a crap. Guess I am gonna just have to play with it some more
Old Dec 8, 2012 | 09:07 PM
  #45
211Ratsbud's Avatar
It definitely takes a quite a while. Search or a thread created by r/ternie here in ecu flash in the past about some sd issues . He shows how his table is set up and might give you a good insight
