EcuFlash Unable to Connect Problem
Old Dec 20, 2012 | 05:05 PM
03GTEvo's Avatar
I got my 1.3U Cable today and thought I would do the Forced Inspection Patch and I'm unable to even read the ECU. I updated EcuFlash and retried it and it still didn't work. I inspected the OBD pins on both male and female and nothing seems damaged. I also looked at both ECU connectors and both also look good. Here is what I'm seeing:
[20:00:25.358] EcuFlash Version 1.43.3252
[20:00:25.358] OS Version Windows 7
[20:00:25.358] Qt Version 4.6.2
[20:00:25.368] 62 memory models read.
[20:00:25.369] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[20:00:25.609] 356 ROM metadata models scanned.
[20:00:25.609] checksum module "subarudbw" loaded.
[20:00:25.609] checksum module "mitsucan" loaded.
[20:00:25.609] checksum module "mitsuh8" loaded.
[20:00:25.609] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[20:00:25.610] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[20:00:25.610] flashing tool "wrx02" loaded.
[20:00:25.610] flashing tool "wrx04" loaded.
[20:00:25.610] flashing tool "sti04" loaded.
[20:00:25.611] flashing tool "sti05" loaded.
[20:00:25.611] flashing tool "mitsukernel" loaded.
[20:00:25.611] flashing tool "mitsukernelocp" loaded.
[20:00:25.611] flashing tool "mitsubootloader" loaded.
[20:00:25.611] flashing tool "shbootmode" loaded.
[20:00:25.612] flashing tool "shaudmode" loaded.
[20:00:25.612] flashing tool "subarucan" loaded.
[20:00:25.612] flashing tool "subarucand" loaded.
[20:00:25.613] flashing tool "mitsucan" loaded.
[20:00:37.390] Using interface OpenPort 1.3 Universal TX2GAQQS138a7fcdb4e5483d05653ab097d209e154b93dc9
[20:00:37.391] interface close
[20:00:37.402] unable to connect to vehicle interface.
If anyone has any ideas I would greatly appreciate any help. I believe my battery voltage is good while trying to read.
Old Dec 20, 2012 | 05:53 PM
211Ratsbud's Avatar
I can't recall for sure if its needed but do you have the flash block plugged in or no ?
Old Dec 20, 2012 | 07:17 PM
Routybouty's Avatar
Make sure the battery isn't too low. Also, see if Evoscan works, that's how I used to determine if it was the hardware or software.
Old Dec 20, 2012 | 07:57 PM
03GTEvo's Avatar
I'm not sure what the flash block is, but I connected both of the connectors on the Tactrix cable. I would like to use Evoscan, but I don't want to pay for it at the moment. Money is a little tight right now since I bought the car and had to throw so much money at it off the bat to fix a bunch of things.
Old Dec 20, 2012 | 09:19 PM
walker992's Avatar
cheak your usb connection to your computer maybe with usb phone charger, i had to get new ones put in because
there were shot.
also when your trying to read the ecu it is it bring the screen where you can choose the different type of vehicles?
Old Dec 20, 2012 | 09:23 PM
jmcmill3's Avatar
^^^ this. i had the same issue and thats what it was. start the process after your car has been running for a sec. it will automatically turn your car off for you. just in case turn off any unnecessary accessories
Old Dec 21, 2012 | 05:58 AM
STLEVOIX's Avatar
Make sure this is plugged in. This was the problem I had because I didn't have it plugged in. Now it works perfect.
http://www.tactrix.com/index.php?pag...mart&Itemid=53
Old Dec 21, 2012 | 02:49 PM
03GTEvo's Avatar
walker992- I no the usb's on my computer are good because it installed the correct drivers whenever I hooked the connectors on the car. It does bring up the screen asking which car I am trying to connect to.
jmcmill3- I tried that method. I tried running the car for a minutes shutting it off and trying to connect with no avail. I also tried to leave the car running while trying to connect also with no avail (Both times I got the same message that I mentioned in the OP).
STLEVOIX- Like I previously mentioned, I made sure the OBD connection and that connection were not damaged and plugged up properly. I have a suspicion the Reflash connector possibly might be damaged further up the wire because I found a connector that was plugged into it with the wire ripped out of the pin. Is there a way I can test the wire on the car side to see if it is the problem?
Old Dec 21, 2012 | 04:03 PM
Routybouty's Avatar
It will still read the ECU even without the reflash connector, so your still missing something. I would try it on another Evo (or Mitsubishi/Subaru) if that's possible and that would cut your things to blame in half.
Old Dec 21, 2012 | 08:47 PM
03GTEvo's Avatar
I could try that. I don't know many people with the cars EcuFlash has on it's list. Hopefully if it is something not acting right on my car, it will be a simple fix.
Old Dec 22, 2012 | 05:33 AM
STLEVOIX's Avatar
ecuflash is always very touchy for me. I tried reading the ecu without the flash connector hooked up and it did not work for me. Hooked it up and everything works fine. If your pin was ripped out of the connector I would start there and make sure its secured. Also is it pretty cold where you are right now 03GTEvo?
Old Dec 22, 2012 | 02:18 PM
03GTEvo's Avatar
STLEVOIX- I meant the previous owner might have used a tuner and used the reflash connector. The wire was ripped out of a connector he plugged in. He left the connector with the ripped out wire plugged into the car side of the reflash connector. And it is fairly cold here in Georgia, around forty or so. The night I tried flashing the car it was about 35 and extremely windy. How does that effect it?
Old Dec 22, 2012 | 06:08 PM
STLEVOIX's Avatar
I always have issues when its cold..I usually have to have the battery on a charger while I am messing with the ECU
Old Dec 22, 2012 | 08:33 PM
03GTEvo's Avatar
Ok, I'll have to try that also after Christmas.
Old Dec 23, 2012 | 08:04 AM
Routybouty's Avatar
That could be. I only tried it once, it was a long time ago. I thought I tried without the flash connector just to see what happens and see if it still worked. I may be mis-remembering, disregard my statement!
