immobilizer window not big enough
Old Jan 13, 2013 | 07:41 AM
c0ke's Avatar
I'm reading everything I can and trying to start into fine tuning my evo, everywhere I read says I need to save my immobilizer code and from what I'm understanding it's a 4 digit code. I've downloaded my rom and xml files and when I open the immobilizer window I'm only getting 2 letters with the ".." meaning there should be more to it right? The window is too small to see the rest and I cant seem to figure out how to get to the rest of the code.
Old Jan 13, 2013 | 08:37 AM
todd6027's Avatar
sorry what rom id can you post the rom
Old Jan 13, 2013 | 08:49 AM
c0ke's Avatar
is the rom id the internal id? 94171715
Old Jan 13, 2013 | 09:36 AM
todd6027's Avatar
add this to the xml
<table name="Immobilizer" category="ECU" address="3ffce" type="1D" level="3" scaling="Hex16"/>
Old Jan 13, 2013 | 10:08 AM
c0ke's Avatar
ok I added that and all it did was give "Immobilizer" its own section called "ECU" however I still only get 2 digits when I check it and try to open it
Old Jan 13, 2013 | 10:37 AM
3gturbo's Avatar
If you cant figure this out you probably shouldn't be messing with your ecu or ecuflash you could damage it or brick it or blow up your engine if you dontknow what your doing.
Old Jan 13, 2013 | 10:55 AM
todd6027's Avatar
attach the def
Old Jan 13, 2013 | 10:56 AM
todd6027's Avatar
negative waves man
Old Jan 13, 2013 | 12:23 PM
c0ke's Avatar
sometimes it's the dumb stuff that confuses us while the harder stuff comes easier. I just wired my eugo to datalog through the ecu and evoscan while I was also able to get the car idling again. I was tuned with a huge vacuum/boost leak that I found yesterday and fixed it then the car wouldn't idle anymore. I've obviously got to spend more time looking at how to expand this box, but for now my main concern was to get it idling again since this car is my daily.
Old Jan 14, 2013 | 04:30 AM
todd6027's Avatar
check what base def files it inherits see if the immobiliser table is in that
ScubaStevo
Oct 13, 2016 02:36 PM
SiC
Jan 19, 2016 08:03 AM
Oettinger
Mar 9, 2008 06:29 AM
CafeRCR
Aug 15, 2007 12:13 AM
TTP Engineering
Jul 7, 2006 10:10 PM
