Unbricking evo 8 ecu
Hi,
I was uploading a tepha file to my ecu (963530706 to 96260709) then the computer crash
I would like to know if there is a way to unbrick it?
I have tried and flash back to the old file. Also the car did not want to start.
Thanks
[19:21:51.402] Using interface OpenPort 1.3 Universal TX2A7FR9553a3ff10c13f8dd93cdf00e4eddd22f75d41f16
[19:21:53.588] sending init sequence 1 (0001)
[19:21:56.864] sending init sequence 1 (0003)
[19:22:00.140] sending init sequence 1 (FFFF)
[19:22:02.901] no response to any known code
[19:22:02.901] interface close
Thanks
Thanks for the feedback. The battery was fully charged when it was flashing. My laptop decided to do a windows update/reboot when flashing the file to the ECU. Annoying as it was all going well till that happened.
But I will keep everyone posted till I find a solutoin.
Cheers.
Cheers.
If your computer dies during the middle of a reflash, never turn the car off. If you leave the key in the on position, you can just reboot the computer and reflash the ECU again with no ill effects.
Too late with flashing with the old ecu as I did turn off the ignition when the computer died. But anyway I had to buy another ECU and had no issue with after I reflashed it.
I'll be attempting to unbrick the unit when I have a chance (most likely making a bench test) to see if I can fix it.
Another expensive exercise but it provided some good experience with it.
Cheers
Cheers
Do not do this. I don't want that laptop to be another zombie comp under some bot herders control. The simple thing to do is ensure the computer is fully up to date and done its updates/reboots before going to flash the car. Same with ensuring the laptop's battery is charged etc. etc.
darwin_evo
Feb 20, 2011 10:47 PM
