At wit's end with Tephra V7
Old Mar 20, 2013 | 01:22 PM
Ralliartize It's Avatar
Tv7 has a sweet amount of features we can all agree. What's killing me is the general driveability:
-Throttle Hang
- Cold Start
- Unstable/Rough Idle
I have been reading threads for months on Evom on how to combat these issues with certain table vaule changes. No dice. Has anyone ever switched to a modified stock map from Tv7?
I can't be the only one who has thought that....
Mod list (nothing special):
Amsoil Intake
62mm Ported TB (Rebuilt by Mil.Spec)
Ported Exhaust Mani
Stock 8 turbo with 10/5 hotside and Megan ported 02 housing
2.5 in DP with RT cat and RM01A exhaust.
Omni 4 bar and GM BCS (tuned to 22psi)
Will post map later when I am home.
Note: Living in Mass I have to keep certain value turned on for yearly inspection.
Old Mar 20, 2013 | 01:43 PM
badev0's Avatar
My tuner was able to fix all those issues in about 20 minutes on tephra V7 with SD. With MAF I never had those issues. More details on your setup may help.
Old Mar 20, 2013 | 01:52 PM
evo8426's Avatar
Post up your tune file and maybe someone will help find the issue. I agree with badevo that you should post up your mods as well.
Old Mar 20, 2013 | 02:06 PM
OP updated
Old Mar 20, 2013 | 06:19 PM
domyz's Avatar
Your symptoms seems similar to the 9417 vs 9653 idle stepper table/iscv tables differences issue.
Old Mar 20, 2013 | 07:03 PM
Map uploaded.
File Type: hex
Old Mar 20, 2013 | 07:13 PM
domyz's Avatar
Originally Posted by Ralliartize It
Map uploaded.
ISCV setting seems okay to me. I mean they're OEM like, not messed up.
Old Mar 20, 2013 | 09:23 PM
Grimgrak's Avatar
dynotech's cold start idle trim thread kills it.
Old Mar 21, 2013 | 04:38 AM
I have seen that thread. Seems to be a bountiful amount of work to make this map driveabale...maybe I'm just acting like an old fart...
Old Mar 21, 2013 | 05:28 AM
domyz's Avatar
Do you have a VTA BOV or recirculated?
You're mentionning that V7 is causing that? So I assume you have a stock ROM somewhere that doesn't have these issues?? Post-it as well.
Old Mar 21, 2013 | 06:07 AM
stunt2's Avatar
I have throttle hang issues when letting off the throttle from boost area
and sometimes stalling issues when parking the car. I'm on oem DV and MAF, 9653 v7 rom.
any fixes for these ?
haven't touched any tables after downloading the rom from v7 thread, ecxept fuel/timing maps
Old Mar 21, 2013 | 06:09 AM
Running the 9 DV recirculated. The stock map I have been utilizing as a control is one you can download from the Evo Ecu wiki - 94170015
Old Mar 22, 2013 | 04:06 AM
How's the driveabililty tephra v5?
Old Mar 22, 2013 | 11:26 AM
domyz's Avatar
It has no effect on whichever tephra version you are. It's all the same base ROM with some new features. If you'd look at the code you'd find that they share about 98%+ of the same code. Your issue is either in the tables or mechanical.
If you say that a stock ROM runs great and 9653 v7 runs poor, find the differences in the tables.
Old Mar 22, 2013 | 11:47 AM
From a mechanical standpoint I've replaced all the solenoids in the EGR system and the EGR valve itself and I have replaced every single vacumm line I could find. New Plugs, clean, MAF etc.
I have done quite a bit table comparisons between the 9417005 and Tephra v7 equivalent ROM and all the would be applicable tables have similar if not the same exact values. This is why am I at such a loss on this. I will spend some time this weekend doing another comparison.
