At wit's end with Tephra V7
Old Mar 22, 2013 | 12:44 PM
domyz's Avatar
Originally Posted by Ralliartize It
From a mechanical standpoint I've replaced all the solenoids in the EGR system and the EGR valve itself and I have replaced every single vacumm line I could find. New Plugs, clean, MAF etc.
I have done quite a bit table comparisons between the 9417005 and Tephra v7 equivalent ROM and all the would be applicable tables have similar if not the same exact values. This is why am I at such a loss on this. I will spend some time this weekend doing another comparison.
If I remember correctly, mrfred has a thread on the right way to deactivate EGR and I think it's related to a change in periphery bits. I just doesn't want to search it from my phone right now .
Old Mar 22, 2013 | 12:59 PM
Ralliartize It's Avatar
I need the EGR turned on in the state of Mass. I will try a few changes over the weekend, but I'm seriously close to paying someone to just fix it.
Old Mar 22, 2013 | 01:02 PM
Kracka's Avatar
Remove EGR, disable in ECU, set ECU to force pass.
Old Mar 22, 2013 | 01:04 PM
ReaperX's Avatar
How did you get the omni 4-bar to work with the EGR on your factory rom? As far as I knew there wasn't any code written to make the omni work with the EGR due to being less sensitive than the JDM MAP? Someone correct me if I am wrong in this. I run the 9417 V7 with the EGR disabled on an omni 4-bar and have no issues like what you have described.
Someone in a state that runs emissions test will have to chime in on all of that as I don't have to worry about it. I love SC!
Old Mar 22, 2013 | 01:11 PM
There was a huge thread about 2 years ago on guys getting sent to super inspection centers due to "odd" values being detected in their ROMS, and some of the force pass parameters were setting off triggers in the state inspection software.
ReaperX - I used this XML in this thread.
https://www.evolutionm.net/forums/ec...evo-8-9-a.html
That XMLnot present me with any issues during my control testing. May be it would have had I pushed the car hard, alas I did not.
Old Mar 22, 2013 | 01:48 PM
ReaperX's Avatar
Here's is the info you are looking for, copied from the thread.
The compatibility instructions here are essentially a copy of my instructions for the JDM 3-bar but with the OMNI 4-bar settings with the exception that I do not include changes to make the 4-bar sensor work with the EGR system test because the 4-bar sensor is not sensitive enough to work with the EGR test. Besides, the EGR test is a sham, and the car will pass emissions with the test disabled.
Old Mar 22, 2013 | 02:37 PM
https://www.evolutionm.net/forums/no...refer-mac.html
Irregardless, I will play my v7 ROM over the weekend and try to get things in comfortable order and still keep my emissions stuff active.
wangboy925
Apr 19, 2016 02:07 PM
Salad
Dec 20, 2015 07:14 AM
glamcem
Jan 3, 2012 08:02 AM
EvoXTX
South Region
Jan 23, 2009 08:31 AM
HiRevnVIII
Midwest Region
Feb 24, 2006 05:49 AM
