Picking up "phantom" knock
Old May 7, 2013 | 07:53 PM
JohnBradley's Avatar
Knock voltage will determine alot. I place almost no faith in det cans either as I have seen motors with "no noise" be subjected to 35psi on pumpgas. A log still tells alot even if the tuner feels it is knock free.
Loose knock sensor will pick up more noise than a tight one.
A bad ground or defective knock sensor will do the same thing.
The shape of the voltage curve can tell stories as well.
Old May 8, 2013 | 12:35 AM
MrJuls's Avatar
Thanks John,now I know where to start looking...time to put on the work clothes.
Old May 9, 2013 | 09:49 AM
MrJuls's Avatar
Found the problem.Down pipe was right against the sump causing vibration and triggering the knock sensor.
Old May 9, 2013 | 09:55 AM
evo8426's Avatar
That's great you found the issue. That is one of the reasons why I stress to make sure exhausts are not rattling against anything when attempting to tune.
Old May 9, 2013 | 10:04 AM
MrJuls's Avatar
Yeah I'm glad i found the issue.Luckily i had a new donut gasket and installed it so it pushes the downpipe down a bit.And this time i didn't clamp the downpipe as hard against the O2 Housing.
Live4Redline
Jul 17, 2024 07:09 AM
4b11slayer
Nov 1, 2016 02:38 PM
miller121mx
30
Sep 8, 2011 12:41 PM
sdfontanini
Sep 9, 2009 08:09 PM
house_of_senate
Jul 16, 2009 07:30 PM
