Force Ready Car for State Inspection Question!
Old May 20, 2013 | 07:37 AM
Inprogress's Avatar
I just made the changes on ecuflash since I failed my inspection for "not ready" on a few things, is this how it's supposed to look? With this, I should pass my inspection?
I also disabled the P0139 (0x0 for value here) and P0140 (put 8000 for value here)
After I flashed my car to this map with the changes made to disable P0139 and P0140, I still have a CEL.
I checked the CEL before doing all of these changes and it was P0420.
Do I just need to cycle the car or clear the code with a reader for it to permanently be gone?
Attached Thumbnails Force Ready Car for State Inspection Question!-screen-shot-2013-05-19-10.33.31-pm.jpg
Old Jun 6, 2013 | 08:29 AM
JohnBradley's Avatar
Or clear it out and then it shouldnt come back.
Old Sep 1, 2013 | 04:06 PM
Risky Guy's Avatar
I had this exact problem.
1st was p0420 cat code
2nd was p0140 diactivated the rear 02.
Ses light back on, did a bung spacer problem is gone.
Did over 200 miles since, I'm ready for inspection.
Just did a pre check.
Old Sep 2, 2013 | 01:55 PM
khaydin's Avatar
Be careful using the forced inspection readiness thingy. In my state (MA) if you enable things that the car doesn't even have you fail and get referred to a government testing center. Also disabling P0140 and P0139 can help you fail. They just turn off the CEL so it masks the problem from you. Best way to handle inspection is to leave anything inspection related stock.
In my state you need to do the following to pass inspection with a modified exhaust system:
1. Make sure the rear O2 is enabled.
2. Make sure P0140 and P0139 are not disabled (so you can see if pop a CEL).
3. Put a vibrant spacer (or any spacer) on the rear O2.
4. Do no use any of the forced readiness patches.
5. Drive for 50-100 miles after making those changes, if no CEL comes up you will then be ready to go for inspection. As long as there's no safety issues with your car you should pass.
Old Oct 9, 2013 | 03:41 PM
01CBR929's Avatar
I've used forced readiness without giving drive cycles to go through emissions. I wish I knew more about the readiness process - but I can say I had to reinstall my o2 sensor and disconnect my analog outuput from my wideband where I was logging through it previously. I got a error in line at the emissions place, cleared it.... and passed literally a few seconds later. Forced readiness worked for me as long as I didnt have another cel showing.
xPRimNT
31
May 5, 2025 05:04 AM
tephra
Dec 17, 2024 01:36 PM
rico05
Mar 29, 2015 07:35 AM
Gfunk101
Jun 22, 2014 10:46 AM
SilverJesterGSX
Sep 30, 2011 10:51 AM
