ECUflash 1.44 cant write .
Old May 23, 2013 | 04:41 AM
mines5's Avatar
Exclamation ECUflash 1.44 cant write .
I am having problem reading and writing with ECU flash 1.44.3719, i have a 1.3u cable.
The read option appears some times and the ECU reads the image and prompts to turn the ignition off. The map shows but when i turn the ignition on [ not crank ] and load the map in ECU flash to write. There is no WRITE option on the main window and ECU option is blank.
WHAT IS CAUSING all this ? OR AM I MISSING SOME MAJOR POINTS on how to write thru ECU FLASH ?
Can any one write step by step how you write your new map on to the ROM using ECU flash ?
PLEASE HELP !
Old May 23, 2013 | 07:42 AM
mines5's Avatar
OK , now i see all the read , test write , write and compare options but when i try to test write i get the following error.
93660005 (71 tables) inheriting evo7base (176 tables)
[18:02:06.033] using metadata XML ID 93660005 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/93660005 2004 JDM Lancer Evo 8 FQ300 MT.xml
which inherits XML ID evo7base from file C:/Program Files/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/evo7base.xml
[18:02:06.033] ---notes---
2012/11/16 [Tactrix] updating to standard file naming.
2012/11/21 [Tactrix] correcting naming for Boost Desired Engine Load 2. Removed - from "Idle Stepper Look-up".
2012/11/19 [Tactrix] Visually examined tables for obvious errors, but no in-car verification has been done.
[18:02:06.064] using metadata XML ID 93660005 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/93660005 2004 JDM Lancer Evo 8 FQ300 MT.xml
[18:02:06.064] ---notes---
[18:04:47.915] Flashing tools do not recognize flash method 'evo'
Old May 23, 2013 | 03:38 PM
bjorgvinben's Avatar
You might need to change the text:
<flashmethod>evo</flashmethod>
to
<flashmethod>mitsukernel</flashmethod>
in your XML file.
That solved my issue when I got the error:
"Flashing tools do not recognize flash method 'evo'"
Old May 23, 2013 | 05:56 PM
mines5's Avatar
to
in your XML file.
OK i have changed it. Today ill try to re-write and update here how things went.
Any other patches required ?
Thanks.
Old May 25, 2013 | 03:49 PM
You might add 2-byte logging into your .xml, if you have not done that already, and intends to use the original ROM instead of tephra.
You can read all about it on page: http://evoecu.logic.net/wiki/2-Byte_Logging
Jake26
85
Apr 30, 2013 11:42 PM
Leftbehind126
Jan 1, 2013 01:49 AM
jeri534
Oct 22, 2009 09:50 PM
downshift411
Sep 18, 2009 06:43 PM
