Unknown new rom ID 52370028
Has anyone seen this rom id or similar before? If I use 52370023 or 52370024 (2008 JDM SST) xml, the LOAD and RPM scaling is wrong.
I will try and flash older rom id above is everything else failed.
Thanks for your help!
Hi,
It seems that the tables of your rom ( 52370028 ) need to be re-defined entirely.
I corrected tables within just timing section. If you need more tables, I can help you but need time to read the codes.
Thank you so much! I can't believe this rom is entirely different than previous romid. Sigh..
Please feel easy. Helping each other is a good point of the community.
I got some time to add fuel section for the xml. ( Cylinder Fuel trim 1-4, Low Octane Fuel Map has not done yet. )
Attached is the 52370028 definition fully ported from 52370024(Golden's definition).
However, there's a point to pay attention to.
In the definition of Golden 's 52370024, since the following tables refer to the same addresses, they should be incorrect of either table(Using tables in the SST categories, be careful.):
1. "Airflow Check Offset" and "SST Throttle Requested Torque Subtractor Map"
2. "Torque Limiter # 1" and "SST Torque Map # 1 - Error (unknown)"
3. "Torque Limiter # 3" and "SST Torque Map # 2 - Cold / Interpolated (unknown)"
4. "Torque Limiter # 2" and "SST Torque Map # 3 - Hot / Interpolated (unknown)"
5. "Torque Limiter # 4" and "SST Torque Map # 4 - Unknown"
6. "SST Clutch Pressure RampUp - Adjust Offset 2D:" and "SST Torque Limit Reduction Table by RPM (CPRU_A)"
