Idle speed
Old Nov 14, 2013 | 04:38 AM
GeoMitsu's Avatar
Idle speed
Evo 9
2006 EDM
88840017-v5.5-mods ROM
Full BBK turbo
M2 cosworth 272 Camshafts
1000 CC PTE Injectors (scaling 835)
Idle speed set to around 852 revs (don't remember the exact number).
Engine hot and running at idle, the Idle speed is = to the value set by ecuflash.
When running with the vehicle and arriving to a full stop (specially after pushing the engine) the idle hangs for approx 5sec sometimes it stays till 10sec around 1200 revs before it drops to the set value.
AFR at idle 14.7 but at the moment of defect the AFR is around 12.5 then when the idle drops the AFR follows it.
Any ideas.
Thanks in advance
Old Nov 14, 2013 | 05:10 AM
lancerrally45's Avatar
Really?
Old Nov 14, 2013 | 08:55 AM
ILuvJDM's Avatar
I have the same issue, in for responses
Old Nov 16, 2013 | 10:11 AM
GeoMitsu's Avatar
Help....
GeoMitsu's Avatar
Any Ideas , any suggestions ?
Plus is there a way to decrease the threshold that the power steering switch intiate ?!?!?
Old Nov 16, 2013 | 10:19 AM
4bangn's Avatar
Originally Posted by GeoMitsu
Evo 9
2006 EDM
Full BBK turbo
Any ideas.
Thanks in advance
I have the exact opposite problem, wen I come to a stop especially after pushing, my idle drops really low I think 500 or so like it wants to die
Old Nov 16, 2013 | 10:24 AM
GeoMitsu's Avatar
If it's able to return to normal idle afterwards then in my opinion this is equal to excessive richness, you shoul adjust scale and latency.
What are the mods on your ride ?
Old Nov 16, 2013 | 10:38 AM
4bangn's Avatar
Yea I am on a rich tune right now, my bov is vta and was told that was probably the cause, intake, exhaust, 35r turbo, stock motor and stock cams, bov is stock as well, I know my injectors are upgraded but cant remember what size, wanna say 880s but not sure
Old Nov 16, 2013 | 04:12 PM
ExViTermini's Avatar
Search for idle hang
Old Nov 16, 2013 | 08:00 PM
ReaperX's Avatar
It can be fixed with adjustments to the idle stepper table.
Old Nov 16, 2013 | 10:14 PM
GeoMitsu's Avatar
Table adjusted and symptom is lesssss
But with the idle stepper table adjustment we will be solving the effect but we are not facing the cause.
What can cause this ?
since the inlet manifold is stock, stepper motor stock, No leak, there is something wrong that made us alter the stock table.
Do you think that the drop of AFR (12.5) pushes the ECU to act in this way ?
Regards
Old Nov 17, 2013 | 04:30 AM
ReaperX's Avatar
Read through this thread.
https://www.evolutionm.net/forums/ec...per-table.html
Old Nov 28, 2013 | 10:42 PM
QuickShiftGSR's Avatar
What happens when you make a change to desired idle-neutral and desired idle-drive?
Old Nov 29, 2013 | 09:17 PM
GeoMitsu's Avatar
The values set for "target min idle" and "target idle with AC" the ecu reaches them but with time lag (after pushing the engine a bit).
When I changed the value in "idle stepper motor table" it became less but I faced the P0505, I returned the values to stoch in order to get ride of the fault.
Since my engine is equppped with M2 272, I needed to set the latency a bit high (attached) in order to reach an stftf changing from -3% to 3% at idle, so i reduced it to get to +24% at idle and the idle hang around 1200 (is now significantly less= result is better than messing with stepper table) and without any fault.
I'm still working on it and I'll inform you of the results ... If I reach any solid ones .
I have doubts specially after reading the post suggested by "ReaperX".
Till then Cheers
raza21_84
Jun 4, 2017 12:29 PM
1fast97gsx
Apr 9, 2015 02:29 PM
r4p.t0x
Jun 29, 2014 10:17 AM
Dochka
Mar 29, 2011 06:17 AM
