Rescaled maps!
Old Dec 6, 2013, 01:06 PM
Toekneee!'s Avatar
Rescaled maps!
So I'm running tephra7. Max load I've hit is about 280. I'm not hitting anywhere close to 350 load so I decided to rescale my tables to max 300. Therefore I can have a smoother transition between cells. That is better correct?
Just want to see what you guys think. If I did something wrong...Thanks guys.
2005 gsr
91 oct in California
TBE
MBC
Intake
Uicp/Licp
What I did was set the last column to 300 and copied the values from my old map to the new one. Then interpolated horizontally and vertically from 100 load to 300.
Old Dec 6, 2013, 01:21 PM
Raptord's Avatar
Yes that's fine. Don't forget to also rescale both fuel and timing maps, as well as low octane, launch and alt maps if you use them.
Old Dec 6, 2013, 01:22 PM
Terror Rising's Avatar
It should help be smoother. Make sure you change all associated maps, too. High/Low Octane Fuel and Ignition all need to be rescaled together.
Old Dec 6, 2013, 01:32 PM
Toekneee!'s Avatar
Thank you guys for the quick response. I just finished my fuel. Now on to the low octane ones.
sleandro
Aug 13, 2017 07:26 AM
richardjh
Jul 28, 2017 03:49 PM
TrendSetter
Feb 16, 2016 09:45 AM
stunt2
May 25, 2012 01:46 PM
Live4Redline
May 13, 2009 07:57 AM
Quick Reply: Rescaled maps!
