Launch bouncing
Old Dec 14, 2013 | 02:32 PM
EvoIXJDM's Avatar
Launch bouncing
Hi guys,
I need your help, my launch map was missing in my new tune, so I copied that part from my last tune, but I think something is missing.
With this maps the car makes 10psi with the 2 step, but when I launch, its bouncing all the time , I try to fix it rising the stationery rpm, but I cant fix it.
I really appreciate your help with this issue, thanks!
Here are the maps, and the video of the launch:
https://skydrive.live.com/redir?resi...t=video%2c.mp4
https://skydrive.live.com/redir?resid=5E001AE497B6F342!408&authkey=!AHYsLlha ElrOELU&=3&ithint=photo%2c.gif
Old Dec 14, 2013 | 02:48 PM
211Ratsbud's Avatar
Do you have a top an bottom clutch switch? Why is the stationary limit at 7000?
Old Dec 14, 2013 | 02:50 PM
EvoIXJDM's Avatar
Yes it has and its working.
Old Dec 14, 2013 | 02:55 PM
EvoIXJDM's Avatar
Because I try to fix rising it, at 6000 is worst the launch, thanks!
Old Dec 14, 2013 | 02:56 PM
Raptord's Avatar
Looks like you're just dropping the clutch too fast...
Old Dec 14, 2013 | 03:03 PM
EvoIXJDM's Avatar
No really, I try a lot of times with the same result, also I had my car 7 years ago , but with this new setup I cant make a good launch
Old Dec 14, 2013 | 04:35 PM
ReaperX's Avatar
Looks like less of a ecu launch problem, and more of a driver launch problem. Looks as though you are just dumping the clutch. That bounce you are getting is because of the shock you're putting on the drivetrain, as well as a less than optimal suspension setup.
Old Dec 14, 2013 | 06:25 PM
EvoIXJDM's Avatar
I have fortune 500 coilovers sets at level 8 over soft position
Old Dec 15, 2013 | 06:15 PM
bambooi's Avatar
Can you stay on launch control a little bit longer? Also you need to log and see whats going on. Check to see if you logged any old launches to compare.
Old Dec 15, 2013 | 07:32 PM
AlphaKennyBody's Avatar
That's definitely a driver error.... Record with a go pro or something we can assist based one that video and logs of course would help. 7K and you can't launch "jumping" sounds like a for sure driver error.
Old Dec 16, 2013 | 10:10 AM
MechTech's Avatar
Sounds like you need to ride the clutch slightly more when launching to load the suspension/drivetrain up. You will know when you do a good launch, the car will sit and go. You shouldn't need to adjust your 2 step.
Old Dec 16, 2013 | 12:03 PM
Toekneee!'s Avatar
Try smoothing out the launch map as well...Once you pass the threshold from launch map to main map, it's going from -20 timing to whatever your main timing is as well as fuel.
runm
13
Sep 1, 2016 06:16 PM
runm
For Sale - Wheels / Tires
Jan 26, 2016 11:02 AM
runm
Jan 10, 2016 05:43 PM
Scratchy
Apr 27, 2015 07:15 PM
JukEboXAuDiO
Lancer Engine Tech
Oct 31, 2014 07:11 AM
