How to tell 1.3u vs 1.3r?
Old Jan 4, 2014 | 11:28 AM
Grimgrak's Avatar
Can't really tell from the photos on the evoscan site but how do I tell which cable that some guy is selling?
Old Jan 4, 2014 | 11:48 AM
vmrevo9's Avatar
Veteran: Air Force
From what i have read there are identical only difference is the operation. Not sure if they come tagged or not
Old Jan 4, 2014 | 11:53 AM
Grimgrak's Avatar
No tag and this is a picture of the pins if it helps.
Old Jan 4, 2014 | 03:56 PM
Broke4speed's Avatar
I have an R cable, purchased within the last 12 months, and it has a single pin in the 12-pin white connector.
Old Jan 5, 2014 | 09:14 PM
evoscan's Avatar
Silver Sponsor
We assemble them from the exact same 100% components for both 1.3R and 1.3U, yes 100% means, same pins, and same plugs.
using the usb plug, there is a special ascii key code programmed into the inside of the 1.3U cable. this key allows the 1.3U cable to work with EcuFlash, this license key adds an extra $40USD to the cost, and is used to advance the research and development of ecuflash versions.
The 1.3R cable can not be used with ecuflash, but can be used for reprogramming Evo7/8/9 using other software such as EvoScan v2.7, and/or EvoScanPPC (gpsnav windows mobile pocket pc).
SOG RA
34
Sep 17, 2015 09:14 PM
mexfizzle
Nov 1, 2011 11:41 AM
EvoJedi77
27
May 26, 2008 06:21 AM
xexitenglishx
Sep 1, 2007 10:28 PM
MalibuJack
May 10, 2006 08:33 PM
