44mm tial wastegate chatter help !
Old Oct 27, 2011 | 08:05 PM
mexfizzle's Avatar
hi this is my second evo i owned and my wastegate never sounded like this can someone tell me why and how can i fix it thank u ima post a vid of it how it sounds at full boost at 24 psi on e85 on a t/3 25g turbo
http://www.youtube.com/watch?v=2Bzl8k13vCE
Old Oct 27, 2011 | 09:48 PM
mexfizzle's Avatar
can anybody help me
Old Oct 28, 2011 | 11:19 AM
ProPilot04's Avatar
Can't hear anything except that sport bike. And thats a street racing video.
Old Oct 28, 2011 | 12:47 PM
mexfizzle's Avatar
thats sounds in the background is the wastegate sounds like its surging bad so i was asking dose a wastegate sounds like that cus it sounds wierd for a evo
Old Oct 28, 2011 | 12:57 PM
Vivid Racing's Avatar
Are you sure that's the wastegate? Sounds like a gnarly misfire or something to me. Also, the TiAL wastegates are the most commonly copied ones out there, as far as I know. Are you sure your w/g is a genuine TiAL?
btw- I'm pretty sure street racing vids are against the rules. Go record a video that shows the sound better and shows less street racing.
Old Oct 29, 2011 | 02:43 AM
mexfizzle's Avatar
yea the wastegate is a real tia 44mm and it sounds like that but ima try to take another vid with no street racing
Old Oct 29, 2011 | 02:48 AM
localtoys73's Avatar
wrong spring
Old Oct 29, 2011 | 06:25 PM
mexfizzle's Avatar
Originally Posted by localtoys73
wrong spring
so u think a wrong spring is the cause of all this chatter
Old Oct 29, 2011 | 06:29 PM
n2oiroc's Avatar
your running it off a solenoid, not a mbc right? sounds like typical solenoid controlled ewg chatter but a little slower. run it off strait wastegae boost and see if it still does it. if not, its normal.
to run it off wastegate pressure, hook the boost referance line to the side port and leave the top port to vent.
yes you need a stiffer spring...do you have a boost gauge? if so you will see the boost taper when you hear the noise its not holding boost.
Old Oct 29, 2011 | 08:51 PM
mexfizzle's Avatar
boost is not steady it jumps around and im running a grimspeed boost contooler on ecu boost map with wastegate pressure
so ima need a new stiffer spring and ima mes around with the lines
Old Oct 29, 2011 | 09:32 PM
yup I put stiffer springs in mine and got rid of ebc for the grimspeed mbc. Nice and simple and it works.
Old Oct 30, 2011 | 10:18 AM
mexfizzle's Avatar
^^^^ thanks bro ima look into it
Old Oct 30, 2011 | 11:25 AM
EvoJoeIX's Avatar
Need a stiffer spring
Old Nov 1, 2011 | 11:41 AM
mexfizzle's Avatar
thanks bro
def1
Feb 2, 2017 10:34 AM
Lanart2011
21
Mar 27, 2016 06:13 PM
djrndm
16
Jul 8, 2010 02:36 PM
eb66
Apr 28, 2010 07:01 AM
4WS Tuning
12
Jan 20, 2006 11:58 PM
