Evoscan - Can't Log Speed
Old Apr 6, 2014 | 02:12 PM
ehall20's Avatar
I tried searching the forums for an answer, but all the results I was able to find had to do with setting up Evoscan's baud rate .
I've gotten almost everything I need to log working in Evoscan (AFR, 2-byte load, JDM MAP, etc.). The one parameter that I can't get to log for the life of me is "Speed". Whenever I select it as part of my logs, all I get are measurements of 0. I'm using Evoscan v2.9.0023 and ROM 88590015. The Request field for speed is listed as "2F" and the function is "1.2427424*x".
The only tinkering I've done with XML files has been to get 2-byte load and JDM MAP logging set up. If I understand correctly, the Request field in Evoscan is referencing that cell in my MUT table. When I pull up the MUT table, however, cell 2F is listed as "2A..." instead of a 4-digit hex number like most of the other cells.
Is cell 2F supposed to be listed this way, or is this possibly the reason I'm unable to log speed in Evoscan? I'm sorry if this is a stupid question, I'm still in the process of reading everything I can to try and wrap my head around this software.
Old Apr 6, 2014 | 02:17 PM
ehall20's Avatar
Sorry, I forgot to add this in my original post. Uploading my ROM for reference.
File Type: bin
Old Apr 7, 2014 | 01:49 PM
jrainwater's Avatar
It won't show "speed" unless you are logging "gear" at the same time correct?
Old Apr 7, 2014 | 06:00 PM
ehall20's Avatar
Didn't know I had to log gear as well, that fixed it. Thanks!
Old Apr 7, 2014 | 07:05 PM
jrainwater's Avatar
No problem, I'm glad it worked for you. My evoscan tells me if I try to log speed without gear that I need to click gear. Yours didn't tell you that? A little thing pops up and says hey log the gear too dummy lol.
Old Apr 7, 2014 | 10:33 PM
ehall20's Avatar
I don't remember getting a message like that, but it's also entirely possible I overlooked it at the time .
evo4mad
May 5, 2015 06:22 PM
Kaveeth
Sep 29, 2014 10:59 PM
Pitside
Apr 29, 2014 04:02 PM
Anubis18
Jun 23, 2013 11:43 AM
