Missing tables? Tephrav7
Old Apr 6, 2014 | 04:05 PM
Toekneee!'s Avatar
So I'm trying to fix rough/stalling idle. I've read that I should adjust "Low coolant temp timing trim map". I cannot find it in my Tephrav7 ROM. I've already increased desired idle in the ISCV tables. Still getting very rough idle/stalling when slowing down to a stop.
Is the table called something else in Tephrav7? 96530706 is what I'm on. Maybe no definition in XML? Thanks in advanced guys.
Old Apr 7, 2014 | 03:36 PM
CDrinkH2O's Avatar
Originally Posted by Toekneee!
So I'm trying to fix rough/stalling idle after installing cams. I've read that I should adjust "Low coolant temp timing trim map". I cannot find it in my Tephrav7 ROM. I've already increased desired idle in the ISCV tables. Still getting very rough idle/stalling when slowing down to a stop.
Make sure your 96530706.xml file has this section:
Code:
 <table name="Low Coolant Temp Timing Trim Map" category="Global Ignition Settings" address="3ff5" type="3D" level="2" swapxy="true" scaling="TimingTrim8">
  <table name="Engine Load" address="6910" type="X Axis" elements="19" scaling="Load"/>
  <table name="RPM" address="68de" type="Y Axis" elements="20" scaling="RPM"/>
 </table>
Old Apr 8, 2014 | 01:46 AM
Toekneee!'s Avatar
^Thanks. My XML file was all screwed up.
Quilem
Feb 28, 2021 01:35 AM
3VOLUTIONIST
Aug 7, 2016 10:44 AM
newbevouser
Jan 2, 2015 07:18 PM
osetsky
Aug 20, 2014 04:23 AM
stunt2
Mar 4, 2011 03:24 PM
