GM 3 Port/ Tephrav7 Help
Old Dec 31, 2014 | 04:35 PM
newbevouser's Avatar
I have converted over from a Hallman mbc to a gm 3 port.
I have looked over multiple threads for install and base tune. I have my ecuflash table set up correctly in both global and main boost control. However I appear to be running gate pressure no matter what I change now.
Yes I've done boost leak test. I was boosting 30lbs with Hallman with no problems.
Yes the ebc is plumbed correctly. Although I have the port left for behind MAF left to VTA.
What could I be overlooking
Thanks in advance.
[IMG][/IMG]
Old Dec 31, 2014 | 07:21 PM
Benja's Avatar
Either it's not plumbed correctly or the solenoid isn't working.
Pulse the output in Evoscan to see if it actuates.
Also, drop those start values to 50% if you have a stock actuator.
Old Dec 31, 2014 | 08:05 PM
Yeah I started at 50% I was in the process of turning it up to attempt to raise boost. 85 was just where I stopped. I will try to actuate via evoscan.
Old Jan 2, 2015 | 06:46 AM
So I tried to manually activate the 3port via evoscan. The solenoid does not click or make any sounds.
Next step will be to test manually. Both harness to assure its getting power and solenoid.
I just want to confirm. Is this a 5v or 12v circuit?
Old Jan 2, 2015 | 07:14 AM
todd6027's Avatar
12v and ecu switches ground wire to activate
Old Jan 2, 2015 | 03:25 PM
riddle me this......
ok so i got my hands on a factory solenoid.... when i activate via evoscan it clicks.. which is good i don't have to chase down the harness.....
next problem....
so if a take the gm 3 port with no harness and apply 12 volts you can here it click. like it should.
(all parts came from spoolin, gm 3 port and wiring pigtail with resistor)....
ok so if i attach the pigtail and try to manually put 12v i hear nothing....
so at this point you would think the pigtail is bad right???
well i tested continuity with the follow with results....
pigtail
wire 1 .0 resistance
wire 2 10 ohm
solenoid 2 ohm
whole assembly 12 ohm when testing the whole circuit.
i am clearly missing something. Thoughts or should i just cut the resistor out and be on my merry way???
Old Jan 2, 2015 | 04:21 PM
CDrinkH2O's Avatar
What about the connector? That is the only other part that could cause the problem I guess.
Old Jan 2, 2015 | 04:34 PM
well i removed resistor and all works. .... so my question now is what purpose does the resistor have???
Old Jan 2, 2015 | 04:44 PM
BlackHawk_Tsi's Avatar
hmm interesting. dont mind me just here to learn.
Old Jan 2, 2015 | 05:54 PM
CDrinkH2O's Avatar
It mimicks the stock BCS resistance so that the ECU driver circuit doesn't flow too much current and overheat the chip. Many people run without the 10 ohm resistor and ve no problems. I wouldn't worry about it. Plug it in and get tuning
Old Jan 2, 2015 | 07:18 PM
ok good. i just wanted to make sure that i dont fry anything. thanks for the help. now if it would only stop freezing rain here i could get out and tune.
Quilem
Feb 28, 2021 01:35 AM
stunt2
Mar 4, 2011 03:24 PM
DaGermanEvo9
Nov 21, 2010 09:30 PM
CornFedEvo
Dec 4, 2009 09:43 PM
