Maf Comp vs Latency question
Old Jun 10, 2014 | 04:10 PM
  #46
mrfred's Avatar
Originally Posted by jrainwater
What brand did you go with for the silicone intake?
The one for my BBK Full and BBK-3B is by HPS, but its pretty much a dead ringer for the Samco intake pipe. The one that I used for the HTA Green is the one that FP makes.
Old Jun 10, 2014 | 05:34 PM
  #47
jrainwater's Avatar
Thanks for the tip, I've always wanted to try the silicone intake as in I heard they work so much better then the steel ones. I like the hps one for the look of it, haha, but I'm pretty sure for performance they're all about equal.
Old Jun 24, 2014 | 02:15 PM
  #48
stunt2's Avatar
Originally Posted by mrfred
negative STFT = lower MAF compensation or MAF scaling
Both tables do exactly the same thing. I ended up setting the MAF compensation to all 128 and then retuning the entire MAF scaling table over the entire MAF Hz range. I found this to be the easier way to create a smooth curve with no unintended spikes or steps. Remember that the car needs to be at steady TPS, load, and rpm for a few seconds before the STFT gives an applicable value. And make sure that the LTFTs aren't changing.
one more question - by how much should one adjust the values ?
for example if the STFT is -8 at given Hz, shoud I lower that value by 8% ?
Old Jun 24, 2014 | 07:25 PM
  #49
mrfred's Avatar
The MAF scaling is more sensitive than that. It should be linear, but its not. For -8% average STFT, I'd probably try lowering the value by 4%.
Old Jun 26, 2014 | 10:34 PM
  #50
mrfred's Avatar
i'm about 95% done doing this very thing again with a new set of injectors on my own car. my curve was already in pretty good shape, so it took perhaps about four hours of logging, analyzing, and tweaking. definitely helps to have a long steady hill with no traffic. a load bearing dyno would be the hot ticket for getting this done quickly. could probably dial it in at 15 points in about 1 hour.
Old Jun 27, 2014 | 12:50 AM
  #51
jrainwater's Avatar
I know you had fic 1100 b4, jw what now?? 2150?? Low or high??
Old Jun 27, 2014 | 09:30 AM
  #52
mrfred's Avatar
I'm trying out the DMT FIC1450s (low-Z, Delphi-based). So far so good. Not any better than the 1100s, but they flow more which is what I need.
Old Jun 27, 2014 | 09:39 AM
  #53
jrainwater's Avatar
Im running the fic 1100 high z's like you were and I love them. A little loud but I can live with that. I have a self rebuilt 9 turbo with a 20g extended tip billet wheel and a 11.5cm turbine (it was balanced after assembly yes). Im @ 25 psi at 70-80 idc lol so im good for now too but what turbo do you have right now? Again, I'm jw.
Thanks,Jason
Old Jun 27, 2014 | 10:29 AM
  #54
mrfred's Avatar
Thanks,Jason
BBK-3B. Estimating about 535 whp. FIC1100s are maxed out at peak power/rpm with the pressure across the injectors holding steady at the standard pressure of 43.5 psi. FIC1450s are right at 80% DC under the same conditions.
Old Jun 27, 2014 | 12:26 PM
  #55
jrainwater's Avatar
Nice, you just needed a little extra. Plus @ 80 dc you have some headroom to add if you ever had to. What are you boosting at peak? Psi-wise.
Old Jun 27, 2014 | 12:35 PM
  #56
mrfred's Avatar
35-36 psi peak at about 4000 rpm, tapering to 29 psi at 7500 rpm. Gotta love the Evo for making boost.
Old Jun 27, 2014 | 03:00 PM
  #57
jrainwater's Avatar
I have my head built to handle that kind of boost but my defi only goes up to 30 so I never tried to tune above 28ish to be safe. Do you have a boost gauge that goes higher then 30????
Old Jun 27, 2014 | 03:27 PM
  #58
mrfred's Avatar
I thought everyone uses a JDM 3 bar or Omni 4 bar MAP sensor now.
Old Jun 27, 2014 | 03:52 PM
  #59
jrainwater's Avatar
I do have an omni 4 bar set up per your instructions, tyvm but a gauge on the dash to monitor that level of boost or no? I know you can data log it but a gauge would be nice.
Old Jun 27, 2014 | 03:56 PM
  #60
mrfred's Avatar
Have a gauge but it stops reading after about 26 psi and no time to look at it when hauling ***. Tune it well and forget about looking it.
