Injector flow rate linearization table
Old Jun 17, 2014 | 01:21 PM
jrainwater's Avatar
Yeah I'm thinking that this issue lays elsewhere then with the injectors although I will say they are the loudest injectors I have ever heard and I used the FIC bypass, not a homemade or eBay bypass. The scaling on 93 is 975 for me and I have the latencies dialed in where my STFT hovers around 1-2 % plus or minus and LTFT is 0.80 so that's pretty darn good I would say.
Old Dec 27, 2014 | 11:54 AM
jeffbeagley's Avatar
Do we have the address for 9653?
Old Dec 27, 2014 | 12:56 PM
SkyNight's Avatar
For the 90550001 ROM, replace "31db" with "3977".
EDM - JDM Evo IX 88570008 ROM
Code:
<scaling name="InjLinearizationPWScale" units="PW Adder (ms)" toexpr="x*0.004" frexpr="x/0.004" format="%.3f" min="0" max="0.5" inc="0.004" storagetype="uint8" endian="big"/>
<table name="Injector Flow Linearization PW Adder" category="Fuel" address="2eb3" type="2D" level="1" scaling="InjLinearizationPWScale">
  <table name="Requested FPW (ms)" type="Static Y Axis" elements="66">
    <data>0.016</data>
    <data>0.048</data>
    <data>0.080</data>
    <data>0.112</data>
    <data>0.144</data>
    <data>0.176</data>
    <data>0.208</data>
    <data>0.240</data>
    <data>0.272</data>
    <data>0.304</data>
    <data>0.336</data>
    <data>0.368</data>
    <data>0.400</data>
    <data>0.432</data>
    <data>0.464</data>
    <data>0.496</data>
    <data>0.528</data>
    <data>0.560</data>
    <data>0.592</data>
    <data>0.624</data>
    <data>0.656</data>
    <data>0.688</data>
    <data>0.720</data>
    <data>0.752</data>
    <data>0.784</data>
    <data>0.816</data>
    <data>0.848</data>
    <data>0.880</data>
    <data>0.912</data>
    <data>0.944</data>
    <data>0.976</data>
    <data>1.008</data>
    <data>1.040</data>
    <data>1.072</data>
    <data>1.104</data>
    <data>1.136</data>
    <data>1.168</data>
    <data>1.200</data>
    <data>1.232</data>
    <data>1.264</data>
    <data>1.296</data>
    <data>1.328</data>
    <data>1.360</data>
    <data>1.392</data>
    <data>1.424</data>
    <data>1.456</data>
    <data>1.488</data>
    <data>1.520</data>
    <data>1.552</data>
    <data>1.584</data>
    <data>1.616</data>
    <data>1.648</data>
    <data>1.680</data>
    <data>1.712</data>
    <data>1.744</data>
    <data>1.776</data>
    <data>1.808</data>
    <data>1.840</data>
    <data>1.872</data>
    <data>1.904</data>
    <data>1.936</data>
    <data>1.968</data>
    <data>2.000</data>
    <data>2.032</data>
    <data>2.064</data>
    <data>2.096</data>
  </table>
</table>
Old Dec 27, 2014 | 05:01 PM
mrfred's Avatar
Updated first post for 96530006 and added SkyNight's 90550001 address.
Old Dec 28, 2014 | 04:58 AM
Benja's Avatar
Has anyone contacted Injector Dynamics for the flow rate data breakdown on the popular used sizes of 1000, 1300 and 2000? If not i'll flick them an email.
I'm keen to make up these correction tables for the 1300's particularly as I believe they aren't quite perfect down low now that I have used a few sets.
Cheers.
Old Dec 28, 2014 | 02:34 PM
Boom, thanks!
Cheers.
I just messaged Paul, hopefully he'll get back to me!
Old Dec 29, 2014 | 02:04 AM
Benja's Avatar
Ok cheers Beagley.
Let me know how you go and i'll chase it up if you don't get anywhere.
Old Dec 29, 2014 | 02:30 AM
merlin.oz's Avatar
I have done it for the 1300s, will get around to posting soon. on another lappy
Old Dec 29, 2014 | 03:01 PM
Benja's Avatar
Ok nice.
Emailed FIC to see if they had this data for 1120 low-z.
Old Dec 29, 2014 | 08:37 PM
merlin.oz's Avatar
Injector Small Pulse Correction for Injector Dynamics injectors.
Attached Thumbnails Injector flow rate linearization table-id1300-inj-small-pulse-correction.png   Injector flow rate linearization table-id2000-inj-small-ipw-adder.png
Old Dec 30, 2014 | 04:51 PM
Thank you Merlin! Will try these out tomorrow morning.
9653 / ID 2000s updated with Merlins Values
<table name="Injector Flow Linearization PW Adder" category="Fuel" address="37c7" type="2D" level="1" scaling="Time_uSec">
0.000
0.032
0.064
0.096
0.128
0.160
0.192
0.224
0.256
0.288
0.320
0.352
0.384
0.416
0.448
0.480
0.512
0.544
0.576
0.608
0.640
0.672
0.704
0.736
0.768
0.800
0.832
0.864
0.896
0.928
0.960
0.992
1.024
1.056
1.088
1.120
1.152
1.184
1.216
1.248
1.280
1.312
1.344
1.376
1.408
1.440
1.472
1.504
1.536
1.568
1.600
1.632
1.664
1.696
1.728
1.760
1.792
1.824
1.856
1.888
1.920
1.952
1.988
2.016
2.048
2.080
</table>
</table>
Code:
312
308
304
300
292
280
264
248
232
220
208
196
184
176
164
156
144
136
128
120
108
100
92
84
76
68
64
60
56
52
48
44
40
36
32
28
24
20
16
12
12
12
12
12
Old Dec 30, 2014 | 07:04 PM
mrfred's Avatar
Changing the linearization values will require a substantial change in the latency value. For merlin's values, I suggest starting by lowering all the latency values by 0.05 ms. With no change in latency, the long term fuel trims will go more negative, especially idle.
Old Dec 30, 2014 | 07:27 PM
merlin.oz's Avatar
^ true that.
Expect to have to tweak the 14 volt AND 11.7 volt latency a bit.
Old Jan 2, 2015 | 05:54 AM
Utilizing Merlin's ID2000 values, Idle on built head and GSC S3s. Target Idle RPM is 1100
Believe it still has some room for improvement, but it doesn't swing near as often as it used to. This is also using the Wideband o2 control patch with no narrowband hooked up.
Old Jan 2, 2015 | 06:00 AM
mrfred's Avatar
Believe it still has some room for improvement, but it doesn't swing near as often as it used to. This is also using the Wideband o2 control patch.
ID2000s and FIC2150s are the same injector, so it might be worth it to try my values or something in between.
