My launch control doesnt want to work
I have tephra mod v7
Its checked off under 1 in the tephra mod options
Under limits I have the launch limit set at 5600
Timing is at 0 and AFR are at 8.5 to try to get it rich......NOTHING
TPPS Threshhold is at 40%
I just had this same problem. All I had to do is open the map I was using and go to (enable/disable Tephra Mod Options) open tephra mod options and make sure you have a 1 in the box where it says enable launch maps. If there is a 0 there that could be the problem. Try that it may work for you as well. I also have 96530706. Good luck hope this helps or at least narrows the problem. I also never used a patch so if this doesn't work that mite.
My bad just noticed you have it checked in the picture.
franzcars
Jul 22, 2025 12:26 AM
DormantBeast
13
Jul 9, 2017 07:38 AM
