Airflow rate lb/min logging really low numbers
Old Jul 18, 2014 | 06:56 PM
gSx's Avatar
gSx
what could be throwing off airflow rate lb/min to make it read only 3 to 4 lb/min when WOT at 29psi and 36 load?
tephra v7 SD
2.2L 10.5:1 4g69 destroker
e85
omni 4bar
gm iat
pte 6466
2150cc injectors
Old Jul 18, 2014 | 08:03 PM
3SgteGuru's Avatar
A lot of stuff, First there could be a leak after the MAF sensor. Or your MAF scaling could be off. Or the MAF could be bad. Or your Logger could just be wrong. You say your Speed Density. So in Tephra V7 theres a table where you put MAF Signal in. That could be mis calibrated
If you could post up your rom and Datalog. It may not be safe to pull to redline so don't if your car is giving you and issue. Just log the areas up to the issue area.
Old Jul 18, 2014 | 08:33 PM
gSx's Avatar
gSx
thanks for the reply, it just started doing this, i havent messed with maf scaling only IAT/mat.
https://www.dropbox.com/s/6c9i3fygo2...7_22.55.55.csv
https://dl.dropboxusercontent.com/u/...S6466w2150.bin
Old Jul 18, 2014 | 08:58 PM
3SgteGuru's Avatar
Which XML are you using
When I drop your rom in ECUflash it cant define it.
Old Jul 18, 2014 | 09:06 PM
gSx's Avatar
gSx
88591517
Old Jul 18, 2014 | 09:24 PM
3SgteGuru's Avatar
dont you mean 88591715
Old Jul 18, 2014 | 09:26 PM
3SgteGuru's Avatar
https://www.evolutionm.net/forums/ec...bles-baro.html
Thats the Speed Density i was using. Its the Tephra V7 with 3d Ve
Old Jul 19, 2014 | 09:42 AM
gSx's Avatar
gSx
Yeah i don't really want to put the 3d ve tables on since 2d was working fine. Since SD gets airflow from map and iat and both are working, I'm not sure what else it could be
Old Jul 19, 2014 | 10:10 AM
evo8426's Avatar
You are logging a ton of useless data, including the airflow lb/min. The only necessary stuff to log is TPS, RPM, Wideband, Timing, KnockSum, Knock Voltage, Load1B, and Boost.
Old Jul 19, 2014 | 10:20 AM
gSx's Avatar
gSx
I'm pretty sure virtual dyno needs airflow to work properly. That's why it's telling me i only make 80hp sometimes lol. Usually 1lb/min is near 10hp depending on VE and other variables. A few days ago it was logging over 60lb/min now it only says like 3lb/min
Old Jul 19, 2014 | 10:27 AM
evo8426's Avatar
Virtual Dyno uses TPS, RPM, and time to calculate power.
Old Jul 19, 2014 | 10:50 AM
gSx's Avatar
gSx
Alright, i didn't know but i figured it would make sense. I'm just applying my Ecmlink tuning experience to the evo. I appreciate it though.
211Ratsbud's Avatar
Vd is math equation based on mass vs accelleration over time
mrfred
Dec 7, 2015 01:49 PM
Boost Demon
Jul 9, 2015 03:15 PM
06Black
10
Feb 24, 2010 07:31 PM
Nuked
Jun 2, 2008 06:32 PM
l2r99gst
Nov 15, 2007 05:35 PM
