Please take a look at my timing map for my E9
Old Dec 22, 2014 | 10:00 PM
BoostingHard's Avatar
Its on 91 octane
Timing on it previously was set at peak at around 6* and -3 at peak boost
I am a newbie and just learning
Old Dec 23, 2014 | 04:01 AM
Tuxevo's Avatar
What you have is definitely better that what you described. You might consider bumping timing in the 200 load column and dropping it in the 210 column. Some general smoothing could be good as well. What load and rpm do you see at peak torque and what is your redline?
Old Dec 23, 2014 | 11:54 PM
MercenaryX2's Avatar
Just for looks, change that 11000 RPM to 9000.
Where are you hitting peak load at and where's it taper to?
Old Dec 24, 2014 | 01:29 AM
okevolutionVIII's Avatar
Post a datalog so we can see were peak load and what cells overall that you are hitting are at.
Old Dec 24, 2014 | 09:53 PM
Im hitting 5* of timing at around 4250 RPM
and 13* at around 7500
prob should retard it a little bit around 1*
will work on my 180 to 210 load thanks you guise are the best
Old Dec 25, 2014 | 04:07 AM
SiriusEvo's Avatar
Veteran: Army
Without a log this is worthless
Old Dec 25, 2014 | 06:08 AM
Tuxevo's Avatar
So load at peak torque is 270/280? Change the cells at 6000 rpm and 250/260 load to 8*. Are you logging any knock? Can you post another screen shot of your updated map?
Old Dec 30, 2014 | 10:41 AM
LetsGetThisDone's Avatar
timing seems high at peak torque for 91. how much boost are you running? Still mostly useless. We need a log file with RPM, AFR, Boost, load, knock count, and knock voltage.
EvoluznCT9A
Aug 13, 2018 07:11 PM
nlp187
Jul 8, 2012 10:32 PM
Bones_OZ
02-03 Lancer Show / Shine
16
Dec 20, 2011 09:45 PM
GOTBOOST1023
Aug 10, 2008 02:24 AM
