Cant log afr via wideband
Old Dec 23, 2014 | 05:33 PM
yeayeaatou's Avatar
I am working with my evox.
I have a serial port and tapped into my aem afr blue data line and grounded that out to the chassis.
I cant get a damn reading to the computer, I can get my gauge to work though.
any ideas?
Old Dec 23, 2014 | 05:38 PM
STLEVOIX's Avatar
The blue wire goes to the rs232 adapter then u need an rs232 to usb adapter. Make sure your comport selected is correct.
Old Dec 24, 2014 | 07:13 AM
yeayeaatou's Avatar
I have that, it plugs into my computer.
I have tried all the options on the log afr also on the drop down menu on the evoscan and evoscan sees my comport
Old Dec 24, 2014 | 09:31 AM
STLEVOIX's Avatar
what rs232 to usb converter are you using? I went through two cheap ones that didnt work before i bought the radioshack gigaware one that works perfect.
Old Dec 24, 2014 | 11:15 AM
yeayeaatou's Avatar
i bought it from bustedfingers motor sports - i might try a radio shack one, I feel like a failure
Old Dec 24, 2014 | 11:35 AM
STLEVOIX's Avatar
the gigaware radioshack works for me on my vista laptop. My buddy has problems on windows 8 64 bit. Just a heads up.
Old Dec 24, 2014 | 11:41 AM
STLEVOIX's Avatar
Just so i make sure you wired it right, you have the blue wire from the aem gauge hooked up to the blue wire on the rsr232 connector correct? It sounds like you stated you grounded the blue wire in your first post.
Old Dec 25, 2014 | 07:26 PM
yeayeaatou's Avatar
I have the blue wire hooked up to the blue wire on the connector and the black wire is grounded to a solid ground.
I will buy a new port tomorrow.
Old Dec 25, 2014 | 07:32 PM
yeayeaatou's Avatar
I am running windows 8, what did your buddy do to solve his logging issue?
Old Dec 25, 2014 | 08:11 PM
STLEVOIX's Avatar
he wired the the white wire (0-5v wire) into the rear o2 sensor slot to log wideband
4b11slayer
May 1, 2022 10:18 AM
xPRimNT
157
Dec 26, 2018 08:09 AM
doom26464
Cobb AccessPORT
40
Mar 23, 2016 07:42 PM
stokEd
51
Oct 14, 2015 06:44 PM
