mpg on 2.3 questions
Old Mar 10, 2015 | 10:30 AM
kaj's Avatar
kaj
Originally Posted by Raptord
The way I see it, with the 2.3/2.4 making more torque at the same rpm than a 2.0 due to the added displacement, it should cruise at lower load, thereby needing less fuel to maintain a speed than the 2.0 would.
I've literally never seen a larger engine with better MPG than a small one( assuming most else being equal). More displacement = more air = more fuel. They have more torque because their are getting the added fuel/air. I could be wrong, though. It's happened once or twice :-P
Maybe you are thinking of gas pedal travel. A larger engine would take less gas (pedal) and RPM.
Old Mar 10, 2015 | 03:34 PM
LetsGetThisDone's Avatar
Originally Posted by kaj
you are in closed loop while cruising, so your fuel and timing maps aren't a factor. as for the other settings? i dunno, since i'm not to great at tuning.
i wouldn't imagine you would be too worried about MPG if you are building a 2.4L with a big turbo. you can't have your cake and eat it too
Timing map is always in use in both closed and open loop. Its the only map for timing advance, and the computer does not do calculations in closed loop to optimize timing like it does for fueling. What's in your timing map is what you get.
I get ~16mpg on 91 octane with mixed city and freeway (80mph) and spirited driving with the setup in my sig. E85 I get about 11-12..
Old Mar 10, 2015 | 06:52 PM
kaj's Avatar
kaj
ah, gotcha. i didn't think about that. i just habitually typed fuel/timing LOL. thanks for the correcting. i was just replying to OP's a/f comment and assumed he was only tuning fuel maps. see what happens when you read the internet half asleep? LOL
Old Mar 11, 2015 | 11:04 AM
robbyredneck's Avatar
thanks lgtd i have noticed about the same. 16-17 since the snow started melting. and leaning out my transition fueling. i also cant quite get my cruise timing high enough. egr adder doesnt do dick. main spark map seems to top out at 39-40* but way better and i have turned it up to 20psi and im at about 75% dc.
Old Mar 11, 2015 | 12:39 PM
the Evo has I think 10* base timing, the timing map is an "adder" over that base timing. So, you have plenty of timing in cruise lol...
shak2300
Mar 13, 2014 11:10 AM
crucialfix
Jul 25, 2012 10:03 PM
wasFWDnowAWD
Jun 21, 2008 10:28 PM
majestic lancer
Oct 13, 2003 07:02 PM
