Having problems with Live Tuner
You need to do a patch on your xml!!
To enable live tuning you need some additional XML!
Put this into your V3 XML file (before the </rom at the end):
<table name="Fuel Injector Scaling" lt-group="0" lt-memory-blk="80501e"/>
<table name="Cranking Enrichment IPW Adder" lt-group="A" lt-memory-ptr="805040" lt-memory-blk="80c030"/>
<table name="High Octane Fuel Map" lt-group="0" lt-memory-ptr="805020" lt-memory-blk="80c050"/>
<table name="High Octane Timing Map" lt-group="0" lt-memory-ptr="805024" lt-memory-blk="80c200"/>
<table name="Reactive Solenoid Base WGDC Map #1A (High Gear Range)" lt-group="0" lt-memory-ptr="805028" lt-memory-blk="80c410"/>
<table name="Reactive Solenoid Base WGDC Map #2 (Low Gear Range)" lt-group="0" lt-memory-ptr="80502c" lt-memory-blk="80c510"/>
<table name="Boost Target Engine Load #1A (High Gear Range)" lt-group="0" lt-memory-ptr="805038" lt-memory-blk="80c610"/>
<table name="Boost Target Engine Load #2 (Low Gear Range)" lt-group="0" lt-memory-ptr="80503c" lt-memory-blk="80c710"/>
<table name="MIVEC Intake Normal Coolant Temp" lt-group="A" lt-memory-ptr="805044" lt-memory-blk="80c800"/>
<table name="MIVEC Exhaust Normal Coolant Temp" lt-group="A" lt-memory-ptr="805048" lt-memory-blk="80ca00"/>
<table name="Injector Battery Voltage Latency Compensation" lt-group="A" lt-memory-ptr="805050" lt-memory-blk="80d100"/>
<table name="MAF Scaling Horizontal" lt-group="A" lt-memory-ptr="805054" lt-memory-blk="80d150"/>
<table name="MAP based Load Calc #1 - Hot/Interpolated" lt-group="A" lt-memory-ptr="805058" lt-memory-blk="80d280"/>
<table name="Calibration Fuel Map" lt-group="A" lt-memory-ptr="80505C" lt-memory-blk="80d6a0"/>
I also ran into this problem, yes Tephra forgot to add some of the code to the definition file, now Liv Map is working.
r3dtr1ckz
51
Jan 11, 2015 09:46 AM
rEVoLed
Sep 23, 2008 12:52 AM
Ryan Bell
Oct 17, 2006 12:21 PM
