Can't Log Fuel Trims
Old Aug 12, 2015 | 03:51 PM
ridenrunwv's Avatar
When I try to log fuel trims in Evoscan all I get is 0.0. I'm using Tephra. I do not get anything in any fuel trim including O2 Feedback.
I logged the voltage on Oxygen Sensor and Oxygen Sensor #2. Oxygen Sensor was always reading 0.9 and Oxygen Sensor #2 averaged around 0.6 and had a range of 0.4 to 0.8.
Anyone have any idea why no fuel trims are reading? I am not forcing open loop in the periphery bit by the way. I did notice I'm logging more airflow at idle than my Closed Loop - LT Trim Control is set to use at Low. I haven't even researched scaling yet but just wanted to make sure I could log fuel trims first.
I'm averaging over 60 airflow at idle and my trim settings are Low > Mid 56.25 and Mid > Low 43.75
I'm guessing my Low to Mid value should be higher than what I'm idling at?
Old Aug 13, 2015 | 09:41 AM
lancerrally45's Avatar
Do you have different injectors? Youre super rich either way, causing an open loop condition.
Old Aug 13, 2015 | 10:45 AM
ridenrunwv's Avatar
I have ID 1300s. I just drove around and things were logging and trims adjusting. Cruising around I was bouncing around 14.7 AFR but at idle I must be open loop because I have no O2 feedback. Fuel trim mid is logging at idle, not low.
Old Aug 13, 2015 | 11:03 AM
Whats your tps voltage at idle?
Old Aug 13, 2015 | 11:17 AM
ridenrunwv's Avatar
I figured out load was what was keeping me from going closed loop St idle. Load values for those RPMs were set to 10 in my tune.
Old Aug 13, 2015 | 11:41 AM
That was going to be my second guess! Good deal. Glad you figured it out. She idle like a kitten?
Old Aug 13, 2015 | 11:47 AM
ridenrunwv's Avatar
Much more lope at idle than when forcing open loop and idling rich. I have S3 cams by the way. I'm having to up my scaling a lot but definitely making progress now. I was like 710 with ID 1300s and idle O2 feedback was pegged at - 25.0
Old Aug 13, 2015 | 12:13 PM
Nice. S3s are fairly decent at a raised idle. If you were on gas, wow.... Id say thats a little off. If its on e85, which Im guessing you are, it should be around 800 with the provided latencies.
Old Aug 14, 2015 | 06:19 AM
ridenrunwv's Avatar
I ended up at 790 and staying +-2.5 fuel trim at idle. I'm messing with my VE Table now to dial in different cruising cells that the trims are not as good on.
Is using the VE table a reasonable way to dial in the areas where I'm getting bigger changes in fuel trims?
Old Aug 14, 2015 | 09:39 AM
Multiply ways to skin a cat. The best way is to do it with the injectors.
Depending how you look at it, to an extent you can use VE to adjust trims.
+-2.5 is good. Id drive around and if your fuel trims are negative I would lower the latency by 3% across the board and then redo the global.... I thinks that the way it goes. Been a day or two since I did my injectors.
Old Aug 14, 2015 | 09:47 AM
Here is a little something for you. Im sure you have this. Figure it was worth posting.
Old Aug 14, 2015 | 10:16 AM
ridenrunwv's Avatar
That's what I was looking at. That and a thread someone made on an Evo X forum. My problem is that I have no idea what my VE should be so at certain loads my trims would be good and they would be bad at other loads. I don't think I can properly scale the injectors if my VE table is messed up. Never would have thought about how that would affect scaling injectors.
Old Aug 14, 2015 | 10:44 AM
If everything looks good at idle you prolly just need to change a few of the cells. Dont block tune. Block tuning on a SD map will only give you problems. Make sure it all blends together. Seems like youre almost there.
Old Aug 14, 2015 | 10:47 AM
ridenrunwv's Avatar
Thanks for the help
Old Aug 14, 2015 | 10:57 AM
ridenrunwv's Avatar
Any idea what sort of VE would be correct around idle cells with S3 cams? I'm obviously off because when I go open loop pulling out the car almost stalls it goes so lean.
